1997 Model R33 GTR
Dark Silver Colour
Engine:
Brand new 2.6 litre (less than 2000km's old)
Tomei Rods, cp race pistons
Nismo Bearing kit
N1 Block
HKS Head Studs
Tomei & Water Pump
Full Ported Head
Brand new Tomei Lifters
Tomei Pro-cams
HKS Cam-gears
Greddy Sump Baffle & Extension
HKS Oil Cooler
Brand new PWR Radiator & silicon hoses
Sard fuel rail & regulator
1000cc injectors
Oil catch can
New Fuel System with Swirl Pot, Bosch 040 pump & Braided lines
PFC D-Jetro Computer
Induction:
HKS tuned length manifold
3.5 Exhaust from turbo to muffler
HKS Wastegate
Brand New Garrett To4z turbo (.84 rear)
HKS filter with Alloy air box
Nismo intercooler (120/600/300)
Greddy Stainless Intercooler pipes & silicon hoses
HKS EVC Boost Controller
Driveline:
Exeddy Twin plate clutch (brand New)
C’s Short shifter
Suspension, Wheels & Brakes:
Tein HA coilovers (Race, alloy body version with full damper control)
Volk TE37 wheels, 18/9.5 all round in new bronze finish
New Falken Tyres
Alcon 6 piston front calipers with 385 mm rotors
Braided lines all round with Ferodo DS3000 pads
Interior:
Sparco Pro 2000 drivers seat with Bride adjustable rail
Willans Harness’s
Nardi Signature Wheel
1 kg & 2 kg Fire Extinguisher
6 point roll cage with full padding
Nismo dash & centre gauge cluster
Overall:
This car has been a constant work in progress since I bought it. Basically everything on the car is new because I wanted a reliable track/weekend car. Everything conceivable has been done to this car without 1 dollar spared. The car has been maintained by GT Auto in Brisbane with constant development & fine tuning. The over condition of the car is good. For more details please contact me on.
$42,000.
Ph: 0411 189 804
Email: [email protected]
Edited by ajc
https://www.sau.com.au/forums/topic/184907-series-3-r33-gtr/
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
