If anyone can help me out with this little pickle...
I am really trying to get my head around VCT and really need to know exactly how it works. I understand the mechanics of it just not what state it is in at what RPM.
please take a good look at the diagrams below. this is my understanding on how it works.
In the above picture you can see there is no oil going to the cam wheel. I pulled out the VCT solenoid and applied power to it and have observed that the holes furthest in are BLOCKED OFF when power is applied making it a normally open solenoid.
In this picture you can see that oil IS going to the cam wheel. this happens when there is no power applied to the solenoid.
What I need to know is, What will happen if i remove the solenoid alltogether. will the cam be advanced 20 degrees all the time?
please only comment if you are sure.
there is a problem with the original oil supply I have tapped and i would prefer to block it off, remove the VCT solenoid and supply oil into the hole it screws into if possible. It took me a while to draw this :worship: so please take a moment to think about it and help me out if you could!
thanks
what do you want to achieve with this?
I run my rb25det with the vct disabled. By disabled i mean its not wired up. I have no blocked it as such.
Now i believe that the VCT only operates in a range of 1400 rpm to around 4000 ish rpm, then switches back off. So if you have it blocked off and have it so its activated all the time you will find you may have a stronger midrange and a lesser top end.
nice diagrams anyway :P
hehe, yeah.. MS paint FTW...
I want to be able to remove the solenoid and use the hole to supply oil to the front cam journal. the head is on an RB30 bottom end so the block does not have an oil gallery to supply the head :dry:
if I remove the solenoid VCT will always be on from what I gather but i really need someone to confirm this. I want it always off.
The way the VCT works is that the cam is retarded below 1400 rpm to remove all valve overlap. This has nothing to do with performance, it just enables the engine to pass statutory idle emissions.
From 1400 to around 4000-4700 the cam is advanced to improve low end torque by allowing an earlier inlet valve closing point. The higher rpm 4000-4700 is different between the DE and DET engines, and different year models.
Above 4000-4700 the cam is retarded to produce later inlet valve closing and improve higher rpm breathing.
All this is just to try to recover what is lost by using such a small inlet cam. If you use a larger cam, say 254 or 262 duration, and you don't care about emissions, it will work better everywhere without the VCT.
The GTR is able to pass emissions without VCT because it has the six throttle body induction. If VCT added anything to performance, the GTR would have it !!!
  • Like 1
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
