Hey there,
Just wanting to know whether someone can point me in the direction of the fittings i need to buy for my rb30.
The engine isnt near me at present so id love to be able to buy fittings and when im next near the thing, put the fittings on.
So the oil return one im after, as well as the oil feed and water feed fittings.
If you can just let me know the size etc that would be superb.
Cheers
Byron
I have no idea about the sizes, but this may help. Probably easiest to unscrew the stock sump drain barb and the water feed plug and take it to a hydraulic fitting supplier to match them to what you need.
I had a custom turbo and head drain adaptor made up...
Go to a wrecker and see if they'll part with them off a blown motor or something. I took all the fittings off my old blown motor and just whacked them on.
They may even give them to you for free!
That looks really good
What did it set you back?
What other things will i need when mounting the turbo(ive got an na block).
if i get get the water and oil feeds and the oil return so i also need some sort of metal fitting before this can then flow off onto braided line?
Anyone else got any good pics?
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
