Straight to the point.
Front seats - $750 SOLD
Rear seats - $350 SOLD
Passenger side upper rear side trim - $75
Both rear lower rear side trims - $100
A-Pillar trims (perfect condition!) - $75
Roof lining - $150 SOLD
Floor carpet - $150
Parcel shelf - $50
Sunvisors - $50
Kick panels - $25 SOLD
Rear seatbelts (buckle and belt assembly) - $75
Roof handles - $25
Centre gauge triple cluster - $100
Centre armrest assembly - $50 ON HOLD
Boot floor carpet - $100 SOLD
Boot side trims (whole set) - $100 SOLD
Space saver wheel - $100 $50
PERFECT R32 GTR Steering Wheel! - $300
Contact - PM me or 0418 881 113
https://www.sau.com.au/forums/topic/207170-r32-gtr-interior-bits/
Rear Seats are sold.
PWND - The roof lining was removed today, and is a paper-based material and will crease if folded. So it would cost a BOMB to post because of the sheer size.
I have removed the rear trim pieces and both lower trim pieces are in perfect condition.
The passenger side upper trim piece is also in good condition, although cracked one mounting point and right in the back corner that gets tucked in under the parcel shelf anyway, so it's inconsequential. Vinyl is still attached perfectly with no lifting or bubbling.
The driver side upper trim did not turn out so good. It literally self-destructed when I removed it, with the vinyl coming off and the plastic cracking in like 10 places. I don't think it's salvagable :(
I have taken lots of pics, and will post them up tomorrow evening.
Thanks mate...
BTW, this is a build date 03/1994 GTR that I'm stripping, with juuuuuuust over 100,000kms..... so the interior is as good as it gets!
Front seats are in PERFECT condition :ninja:
  • 1 month later...
  • 3 weeks later...
Guys,
The front seats are in PERFECT condition... Out of a 1994 GTR, with no tears, rips or wear marks at all. Side bolsters are still firm and in original shape! No fat-asses have sat in this car :P
Complete, with rails, ready to bolt in!
$700 takes them away.
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
    • Highest combustion temperature is achieved at 14.7:1. (or, I should say, lambda=1, because 14.7 is not constant for all fuels). NOx increases exponentially with combustion temperature. So it is in the engine designer/s best interest to find a way to operate at lower than stoich max temperatures if they want to minimise NOx. If you want to minimise CO, you really need to run at least 14.7:1. Any extra fuel can realistically only ever report to NOx. O4 HCs if you are sufficiently sub-stoich, or if the engine's fuel-air mixing is up the shit. All of this presumes that the catalyst is not doing anything, of course. In reality, the cat is there, it is doing things, and how capable it is of eliminating either NOx or CO will depend on its age, quality, design, operating temperature, and how much the engine/ECU is designed to help it along, with fuelling strategies, air pumps, etc. And of course, RBs, even those with very capable aftermarket ECUs, usually don't have anything to help. They are just tuned to make power.
    • It's... way cheaper than what SP have on their website? I can only imagine if I say "can you make this muffler, but entirely different dimensions outside of the spec you offer as customization on your page" it would get even more pricey. I was looking at their race mufflers or their 'ultra quiet resonators' which are just smaller mufflers. They start at $166 USD which is $264. SP mufflers resonators start from $299 and are too long/not wide enough/can't be made short enough.
