Fuchs oil saved the day! only damage was bigend bearing #1 started to come apart, but it didn't spin, and didn't mark the crank. So all I need to do is replace the bearings and it's good to go
Are those bushes one piece or two? I've been using bushes similar to the link below for around 8 years will no issues. My car isn't a track car, but is driven reasonably hard at times...
http://www.ebay.com.au/itm/SuperPro-Caster-Rod-Bushes-S13-S14-S15-R32-R33-R34-Z32-/170725212086?pt=AU_Car_Parts_Accessories&hash=item27c003ffb6
The current ones are 2 piece, but i've also killed a set of single piece ones. they are the softest part on the front suspension, so it's understandable that they are the first to fail under circuit loads
  • 1 month later...
My 20 cents worth;
A GTR (4wd) front swaybar won't fit a GTST (2wd).
I was looking back through this for some info, and I came across this. Fun fact, a GT-R swaybar does fit on a Gtst. I don't run one, but I recently fitted one up to another Gtst.
Beauty, i've been looking for a while for confirmation on this.
Did you end up going for speedflow fittings on the cooler or go full braid?
I'll keep on with the pushlock fittings, but i'll replace the sus one with a speedflow one. I'm still waiting for my bearings to arrive, they are made in Launceston by ACL, shipped to the mainland, then bought back.
I've been working on the car but forgetting to update the thread, the car is currently on jack stands with the engine out. I just sent the shocks off for a revalve, and I shoudl have the engine back together this weekend.
  • 4 weeks later...
Well I have finally got my engine back together. just waiting on getting the flywheel buzzed, and it can go back in the car.
Shocks are back from being re-valved, and are back in the car.
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
    • Highest combustion temperature is achieved at 14.7:1. (or, I should say, lambda=1, because 14.7 is not constant for all fuels). NOx increases exponentially with combustion temperature. So it is in the engine designer/s best interest to find a way to operate at lower than stoich max temperatures if they want to minimise NOx. If you want to minimise CO, you really need to run at least 14.7:1. Any extra fuel can realistically only ever report to NOx. O4 HCs if you are sufficiently sub-stoich, or if the engine's fuel-air mixing is up the shit. All of this presumes that the catalyst is not doing anything, of course. In reality, the cat is there, it is doing things, and how capable it is of eliminating either NOx or CO will depend on its age, quality, design, operating temperature, and how much the engine/ECU is designed to help it along, with fuelling strategies, air pumps, etc. And of course, RBs, even those with very capable aftermarket ECUs, usually don't have anything to help. They are just tuned to make power.
    • It's... way cheaper than what SP have on their website? I can only imagine if I say "can you make this muffler, but entirely different dimensions outside of the spec you offer as customization on your page" it would get even more pricey. I was looking at their race mufflers or their 'ultra quiet resonators' which are just smaller mufflers. They start at $166 USD which is $264. SP mufflers resonators start from $299 and are too long/not wide enough/can't be made short enough.
