i'm part-way through my new project bmw build which previously had an RB20 (QLD plates: RBE36). New engine is RB26 using the stock turbo's for now.
all the work is done by myself and 3 mates who dont take things too seriously, most of our inspiration comes in liquid form available from the bottle-o -> www.drydenmotorsports.com
we make a few products including battery relocation kits and alloy/steel intake kits for mitsubishi EVO 4 to 6.
anyway just a couple of pics of recent pipework we did on the BMW, in 3 inch alloy. Have also just completed full stainless exhaust including front pipes/dumps will post pics of that when i take some
Chris.
EVO 4 to 6 intake pipe:
RBE36 (E36 bmw w/RB26):
post-30449-1257138581_thumb.jpg post-30449-1257138587_thumb.jpg post-30449-1257138592_thumb.jpg post-30449-1257138596_thumb.jpg
https://www.sau.com.au/forums/topic/294529-bmw-with-rb26/
bigger pics please - but is this going to be a full build? step by step with updates?
just wanted to put up some fab shots of the piping.. i'll ask my mate for bigger pics!
the entire build can be found http://forums.eurocca.net/showthread.php?t=17736&page=14
https://www.sau.com.au/forums/topic/294529-bmw-with-rb26/#findComment-4913641
I'm a great fan of the E36 BM Look.
So I greatly anticipate how this project turns out - all the best!
Much swearing so far? And over what bits? Or no tool-tossing yet?
Yes it's good the RB25 gearbox has gone in without probs... :P
https://www.sau.com.au/forums/topic/294529-bmw-with-rb26/#findComment-4914726
cheers,
its actually been a pretty smooth build, since we did the conversion to rb20 first back in 2006, it paved the way for any rb motor conversion, so the 26 build has been a breeze (though costly!)
power to weight and cost to performance, i really can't complain - still is cheaper than an M3 conversion (which would have grabbed me ~200rwkw)
the only problem we keep running into is the capability of the stock diff's, and lack of diff upgrade options for these cars ($1100 for a used LSD with 3.4:1 gears, would be crap behind the 25 box, so another $400 for 4.10's plus resizing the tailshaft to suit..)
one diff from the stock 318i (open centre) lasted me 2 1/2 years before giving up the ghost, so they are stong from factory, however not suited to track work, and i still dont have an LSD... will definitely want one by the time the 26 is on the road.
https://www.sau.com.au/forums/topic/294529-bmw-with-rb26/#findComment-4914877
  • 2 months later...
  • 2 months later...
  • 3 weeks later...
  • 4 weeks later...
this is a brake kit i've developed using cheaper OEM parts.
* 2 pot PBR Calipers VE SS Commodore
* 345mm x32mm thick Rotors machined to suit e36 (5x120) Mercedes ML55 AMG
* Lazer cut 16mm thick mild steel caliper bracket
* Machined mild steel bosses
* HT (8.8) bolts
post-30449-1275350410_thumb.jpg post-30449-1275350430_thumb.jpg post-30449-1275350449_thumb.jpg
post-30449-1275350457_thumb.jpg post-30449-1275350465_thumb.jpg post-30449-1275350472_thumb.jpg
comparison OEM setup vs new setup (both pics are 18" rims):
Edited by kristafa
https://www.sau.com.au/forums/topic/294529-bmw-with-rb26/#findComment-5266415
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
