Well guys and girls, I have decided that I have other things in life that I need to chase.
I.e. Having somewhere to live, so although its only JUST been built i've decided to sell the RB28 i have sitting downstairs.
All work was completed at JHH here in Brisbane and I have receipts for it all.
Basically i'm chasing 50k ONO. for the engine, she's brand new, not even been started yet.
The list of parts is the following:
Tomei sump baffle
Tomei oil pump
24U N1 block
Tomei 2.8L stroker kit - Crank, Rods and Pistons with cooling channels
ATI balancer - 1000hp varient with additional pulley for water pump
ARP fasteners throughout of course.
ACL race series bearings
Tomei headgasket
New Nissan thermostat
1mm oversize valves for intake and exhaust.
Bronze valve guides
Oversize valve seats
Head flowing and porting to suit.
Head matchported to injector plate
Supertech dual valve springs
Titanium retainers
Custom 272 @ 10.55 mm lift degree cams
Greddy cam gears
Gates Racing timing belt
Tomei dual entry fuel rail
Sard 800cc injectors
SARD adjustable fuel pressure regulator
Garrett T04Z
Custom manifold with true split pulse collector
Twin 38mm Tial wastegates
Custom dump and wastegate plumb back pipes to suit a 32gtr.
The engine also had:
Bore and torque plate hone block
Block was decked.
New welsh plugs fitted
New seals, bushes and hoses all round.
Throttle bodies were stripped, cleaned and serviced.
Basically this engine is good to be dropped straight in and go.
Again, I am asking $50,000 ONO. Please, obviously no stupid offers.
You can contact me on mobile: 0421 933 614, if you call and I don't answer just leave a message or text me.
Email: [email protected]
I am located in Brisbane, just north of Mt Gravatt.
Would prefer local pick up, BUT CAN organise transport interstate if required, obviously at buyers expense and understanding that no damage is covered (and transport company's won't cover damage either).
Edited by scissored sil
https://www.sau.com.au/forums/topic/299397-rb28-complete-engine-for-sale/
Here are some build pics as well:
I forgot to add, the engine at the moment is setup for a power fc Djetro.
If the buyer is keen, I do also have this, brand new.
hey mate,
if you do find a buyer for this engine, any chance that you have all the recipts for the parts and labour?
cheers, very nice engine, also you forgot to mention the greddy plenum, and the greddy alternator pulley, and the aftermarket water pump pulley...
hey mate,
i'm fairly confident that nick does have reciepts for everything, theres been a shitload of time and effort put into this build, and will at JHH did a fantastic job with this motor.
^^ :P Ok tool...show me where the 50k grand went then ?
Most people know what an n1 block & hks stroker kit is worth...i didnt realise there was 35 k in the top end etc.. :P
yep, sorry just noticed that he said that they are there...
also to the other comment, that this is over price or what-so ever, it doesn't matter what your personal opinion is, if he doesn't sell it, surely he will keep it...
also just wondering, is there any loom etc that you have left out of the description? also are all water lines, sensors etc new? if used, how old are they? but judging by the build, everything should be brand new.
^^ :) Ok tool...show me where the 50k grand went then ?
Most people know what an n1 block & hks stroker kit is worth...i didnt realise there was 35 k in the top end etc.. :down:
Knew this would happen... Thread cleaned.
Look i don't care if you think the price is utterly outragous or not...
Anyone with half a clue knows what costs what... but leave that for the buyer and seller to discuss.
Reciepts will soon show the actual vs the perceived cost.
Keep it clean.
hey mate, could you please answer the above questions... cheers
Yeah I do have the engine bay component of a wiring loom for it, coil packs and wiring, the water and oil lines are new. I did use some of the sensors, i.e. knock, off the original engine from my GTR, and they'd been working fine (was a running engine when i pulled the stock one out)
Best of luck with the sale Nick, Shame you didnt get to let the animal out of the cage.
Even if the price is steep, I know if i had the right money sitting here it would be in my garage (along with that fking gtr of yours)
I can vouch Nick that everything that is listed, IS in the motor!
We should convince Wazz to buy it.... well take out a epic loan for it :down:
Edited by Force Fed
By the way every one, at this price, it will also including cooling piping to suit a 32 gtr, greddy type r BOV, plumbed back in that piping, cooling pro 600x300x100 IC.
And seeing as the asking price might be a little ambitious, now asking $45k.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
