hi guys its not a skyline but it is will be rb powered. Roughly 6 years ago i bought my self a 1973 240z
I bought it with plans to do a full restoration and rebuild for a tough streeter with the occasional track day.
I origonaly planed and had the gear to build it with an l28et which isnt a bad thing because they can be very power productive with the right set up.
but i recently found a compleat rb20det and every thing i need except the fuel pump set up to get it running in my s30 hence the reason i am here on this forum
Here are are some pics with with where i am at with the build
this is how it was when i bought it
i had the dash redone by rear spares
i bought some willwoods
cleaned up the suspension
I did a lot of body work and rust repair including replacing the roof skin to get rid of an unwanted sunroof
fit up some fender flares
off the rotisserie and a panel fitments before doing finishing off the body work
and finally my rb20 waiting to be fitted up
https://www.sau.com.au/forums/topic/342533-rb-240z/
im a little bit far away from you. I am in south australia You should get your self another zed to play with.I sold mine to buy an r32. I missed it so much i sold the r32 to buy another zed. I would not swap it for any thing. Just today i had some one wanting to swap it for a late 90s, bmw. I told him hes dreaming :)
https://www.sau.com.au/forums/topic/342533-rb-240z/#findComment-5530953
  • 5 months later...
thought i should do a quick update and show you where i am at
here she is getting some sun on my front lawn
thought i should fit up the intercooler before i paint it
there was not much to it the pipes lined up with the factory vent holes..
I just had to make them a fraction bigger
I now have it at the crash shop were i work awaiting primer so its not far
from paint..
It is a shame that these rims dont fit as they are 5 stud and came off my bosses GTR
If any one wants them they are for sale
https://www.sau.com.au/forums/topic/342533-rb-240z/#findComment-5775124
  • 3 months later...
  • 1 month later...
Hi guys.. Its been a while since i posted so this is were i am at.
I got some rims they are rota rbx in 17x 9.5 for the rear and 17x9 for the front.
I managed to get some time in the spray both to spray some high fill primer on all the panels. now i just need to block it back and wet rub it
and it ready for color
https://www.sau.com.au/forums/topic/342533-rb-240z/#findComment-6036144
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
    • That looks a bit like yellowing to me. If the rear bar was looking like that from rich idle, I'd ask the question, do you have a catalytic converter fitted, and fully working?
    • Oh yeah gets really bad down here. I’ll have to upgrade the heater and wind screen wipers as well for optimal performance.
