R34 Stereo Head Unit Wiring Diagram For Pioneer Deck & Handbrake Bypassing
Hey guys,
Just thought I'd make a DIY post for people wanting the correct wiring diagram for connecting a Pioneer head unit ...
Im making this post because I struggled with the general diagram and the colours were not matching correct so if you got Pioneer, your in luck.
Pictures are attached but I wrote it down also:
NOTE: May work for other models but this is specifically for R34 Skyline with a Pioneer Head Unit.
Car: Dark green - Stereo: Yellow
Car: Orange with black strip - Stereo: Red
Car: Red with blue strip (in image below its yellow.. used to extend it) - Stereo: Orange with white strip
Car: Grey with blue strip - Stereo: Blue with white strip
Car: Orange - Stereo: Purple
Car: Black with pink strip - Stereo: Purple with black strip
Car: Pale green - Stereo: Green
Car: Black with yellow strip - Stereo: Green with black strip
Car: Brown - Stereo: Grey
Car: Brown with white strip - Stereo: Grey with black strip
Car: Blue with white strip - Stereo: White
Car: Blue with yellow strip - Stereo: White with black strip
Hope this helps if you needed it..
Also if you need help with bypassing the handbrake I worked it out too, if its an old model DVD head unit you can just tap the wire labeled handbrake into the ground wire and this will allow you to have the DVD open while driving.
Although if you have bought a new model pioneer head unit, you cant just ground it, it wont work so what you have to do is on the wiring harness that comes with the pioneer head unit, there will be a wire labelled "mute" (this wire is not needed) so remove it without damaging it and you will need to move it to another port on the plug. You will see on the plug where the wires come out that there are two black wires coming out, but there is a empty gap between them.. now insert the mute wire into this port (make sure it clicks in). Now strip the end of the mute wire and tap it into the handbrake wire. Now that the mute and handbrake wire are connected together you can now ground it or tap it into the ground wire. This will then allow you to have the DVD screen on while driving and if it has a GPS you can now input the address without stopping the car and pulling up the handbrake first.
I know the handbrake bypassing sounds complicated if you have the new type but ill be glad to help if you want to ask any questions or need more detail on certain steps.
Very helpful Benny boy.
This should be stickied. This is the only thread you will find showing what the factory R34 stereo wires connect to.
Edited by PAV34
  • 2 months later...
Hey, I Got new Pioneer AVH-P2300 DVD unit and wanna know how to Bypass hand Brake on this Unit.
1) do i need to Buy any add on Device to work ?
2) Any simple trick & tweak?
Thanks in Advance
the way i bypassed my clarion dvd player is a switch yeah shonkey but not as bad as not having dvd screen at all, just a wire from the ground to the switch and the handbrake wire off the deck to the switch, in the ashtray and tadaaa you want dvd just flick the switch.
  • 2 years later...
IMO this should really be (for ease for everyone who is doing this):
Car: Dark green - unswitched power (battery)
Car: Orange with black strip - switched power (ignition)
Car: Red with blue strip (in image below its yellow.. used to extend it) - illumination (so when your dash lights come on, the screen dims so it doesn't glare at night)
Car: Grey with blue strip - remote (or antenna?)
Car: Orange - rear right speaker +
Car: Black with pink strip - rear right speaker -
Car: Pale green - rear left speaker +
Car: Black with yellow strip - rear left speaker -
Car: Brown - right front speaker +
Car: Brown with white strip - right front speaker -
Car: Blue with white strip - left front speaker +
Car: Blue with yellow strip - left front speaker -
For the earth you can just put a ring terminal under the bolt on the panel holding the gear shift boot. Easy to access.
Edited by sleptema
  • 3 weeks later...
Perfect thanks lots!!!
  • Like 1
  • 9 months later...
Just for anyone who might be wondering, in GT-X models that included the Xanavi GPS/TV Package & Skyline Holographic Sound option from factory, the antenna booster wire is actually red with a white strip. There is still a grey wire with blue strip in the loom, but at this stage I haven't been able to work out what it actually does.
  • 3 months later...
just found out today while hooking up a new head unti into my sedan with holographivc sound - the grey with blue is the amp for the rear speakers. crappy flat sound from the back if the hu remote turn on wire (blue with white stripe) isnt hooked up to that wire, full sound when connected. its the standard nissan amp power on wire
  • Like 1
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
