Guys I wired in a new fuel pump into my 34 GTR and found it didnt work(and yes I got the wires correct and yes the pump works when tested elsewhere).
After that I resoldered the original fuel pump back in to check if it was a resistance thing etc, but that didnt work either, there is no voltage from the wires at the fuel pump
So for the moment I have just added a new relay in and got the power from the ignition circuit to switch the relay on and have the fuel pump direct battery voltage feed.
But I would really like to get the orignal circuit working. The fuel pump fuse is fine. I have checked all the fuses in the boot, near the drivers kick panel and under the near the jump start point in the engine bay. Are there any other fuses or can someone tell me where the fuel pump relay is actually located.
My understanding so far is that the ECU fuel pump relay signal puts out .6v (checked against another ecu in my car), from there I think it goes to an earth controller of some sort and then switches the relay on.
Im just shy of tracing wires, but if anyone can give me a heads up on how the circuit works i would be rather greatful.
Edited by sinistaGTR
https://www.sau.com.au/forums/topic/379292-r34-gtr-fuel-pump-electronics/
well.... the fuel pump relay control on the ecu is actually contolled by the inputs the computer receives.
There is a fuel pump drive controller that turns the relay on and off.
Whan i turn the key on i get .6v for 3 secs so this indicates that the the signal is working fine (manual says approx .8v). Seems i may be having trouble with this drive pump controller.
Anyone know where this drive pump controller or the fuel pump relay is located.....im getting closer to this problem
Ok so quick update.... I took the battery terminals literally off then back on....and BAM 12v out the original fuel pump wires....so now have the 14v direct feed relay with the original fuel pump wiring being the swith for my relay....
random electronics lol
  • 1 year later...
bringing up an old thread, went to start the car this morning and it cranked fine but wouldnt kick in...
after abit of investifating we believe its probably the fuel pump as i was not getting any sound prior to cranking (power not getting to the pump??)
checked kick panel, front and rear fuse boxes, all looked good. tried unconnecting the battery and restarting with no luck..
i have a haltech platnium pro plug in that and i will take the laptop down tomorrow and try and see if anything pops up on the logging, and maybe rebooting the ecu (not sure if disconnecting the battery would do this anyways?)...
anyone have any ideas or tips, advice to solve the issues that seem very similar to the above.
any help will be greatly apppreciated.
Cheers,
Anthony
Relays are under the rear rt tail light. Make sure you are getting a pulse on that relay and there is 12v on it.
thanks for the tip mate, was wondering where they are.
im pretty hopeless when it comes to fixing things but will give that a shot tomorrow.
just under the internal boot side wall carpet? or further?
Hey mate,
Anything else i should check after doing the above test? what should i check if it is? or if its not etc?
thanks
u need to test the power at the fuel pump not the relay. and remember u need to test it while either cranking or wiyhing the first 3seconds or so while its supposed ti be priming once key on
Thanks mate, i will look into doing this on the weekend and go from there.
Cheers,
had another look at my issue this morning, and it appears that im not getting power to the relay or the fuel pump.
has anyone had these issues before? from research and looking at wiring diagrams etc it appears the fuel pump control module could be broken. may have to look at hard wiring the pump direct to the battery to fix this? does anyone know an easy way to test if that is 100% the problem, or would be the fact that the pump isnt getting power proof?
here is the wiring diagram i found for reference.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
