Up for sale is my set of 18inch ROH Modena 3 piece Rims with tyres, as most people know these rims are not of the shelf items and are to be custom made by ROH, i had these on my R33 and looked absolutely amazing with the staggered offset!
The rims are in fantastic condition i have always washed them and kept them in great condition, few minor imperfections but nothing major, tyres have lots and lots of tread.
Measurements
(5x114.3)
Front Rims (18x9)
Front Tyres (235/40R18)
Rear Rims (18x9.5)
Rear Tyres (245/40R18)
Im looking for around $1400 ONO, throw offers at me as i need them gone on the asap due to new rims coming within the next 2 weeks :)
Dont hesitate to call or msg me with any queries my number is 0402930153 will get pictures up as soon as possible
Edited by SLY333
willing to have the wheels freighted to your doorstep by fastway couriers had fairly cheap quotes by them so far of around $100 to $200 for all four wheels delivered to your doorstep! NEEED GONE ASAP
Don't forget these are 3 piece fellas, ROH will make you up any size lip or barrel for $160 a pair!! Huge possibilities.
That would be correct, These rims are in Mint condition honestly need them gone all reasonable offers accepted
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
