Ok, so i needed a new shim kit for my r33. Ive got the 4 pot calipers on the front, searched for a part number, 41080-21U25 is apparently the one i need.
This, according to quite a few people, is 41080-21U25:
So i went to my nissan store, forked over a large amount of cash for that part number. Except when i got it, it looked different.
I scoured the internet again, rechecked the part number, and its definitly the one from what i can tell. It says that number on the packet I got.
Is it possible nissan can stuff it up? It came in one pack.
Id just like some confirmation. Any help would be appreicated!
Edited by Nights
https://www.sau.com.au/forums/topic/403204-front-brake-shim-kits/
It was $170 off the top of my head.
Oh really? Whats I find very weird though is that the outer shim (the silver part) doesn't cover the whole piston. It gets about half of it to 3/4.
The ones in the other pic i posted first look like the correct shape, they would cover both pistons completely.
The kit in the first post looks the same as the R32 GTR (sumitomo calipers) and IIRC the 33 gtst calipers use the same pad. The shims match the profile of the pad backing plate. So what you got doesnt looks right - but i checked the part in FAST and it came back with the same part number....weird.
Is this what your looking for? http://www.frsport.c...re_p_12970.html
Yeah i saw these originally, and they look like the exploded view of the r33 brake, but yeah, it said 300zx so i thought id be safe and go through nissan.
Yeah doesnt quite look right to me either, from a design standpoint im struggling to see why only half of the pistons are covered. Yeah its definitely the part number, although its weird cos on the exploded view they definitely match the pad backing plate. Dont look like the ones i got.
When I took off my shims, the silver ones only covered about 75% of my black metal ones =S
This is off a stock r33 gtst. Here is a pic
Yeah? Maybe it is correct then. Just seems a little weird it only covers half the calipers, not to mention its not even even, it covers different amounts of both pistons :S
This is confusing.
Edited by Nights
Mine had diagonally cut silver pieces too (R33 GTS-t brakes), apparently this plate profile helps with vibrations somehow, I've seen exactly same thing done to STI and some euro cars' backplates, so your kit is the correct one
  • 11 months later...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
