R33 Kmh To Mph Converter Problem
ncno
 Share
Hi,
Seeing this is my first post, I better say it's great to be here. Sorry my first post is regarding a problem.
I've recently been taking my interior more or less apart. Doing this, I found a KMH to MPH converter connected behind my cluster. This is what it looks like disconnected.
Clearly it is AFM. Probably installed by the guy who had the car before me.
I took it out due to two reasons.
1. I would like it in km/h if possible.
2. I didn't like the quality of the install.
The green and red wire goes directly onto the cluster - Two screws securing it. They are located around the back of the speedometer.
The blue wire goes from the black PIN-connector (Upper row, 2nd from middle). Original wire is grey with 2 red lines.
Yellow wire goes from the bundle of cables which is behind the cluster. Also grey with 2 red lines.
The converter says as follows:
Red: 12v
Green: Earth
Yellow: KMH signal input
Blue: MPH signal output
I am not a 100% sure the yellow wire goes from the bundle and the blue from the PIN. Perhaps it's the other way around. If necessary, I will naturally make sure as soon as I am at the car (it's parked in a garage for the winther).
I've had a voltmeter onto where the yellow cable was connected - With the engine running it occasionally gave a small reading. Note: It was only in idle.
Is it possible to just connect the 4 wires (2 from the car, 2 from the speedo-cluster) to get a KMH signal, or should I just reinstall the converter? Furthermore, how should the 4 wires be connected to one another?
Car spec:
Skyline R33 GTST S2
Haven't been able to find any answer. I hope I'm not asking a stupid question. Any help is much appreciated.
 Share
