Well looking closely the first letters look like Gr.A (Group A) followed by R32 and then something in asian (probably refers to honey chicken or the like), and then WET (wet weather tires, as the ones in that picture have tread and aren't slicks).
Total, Impul and Nismo logos are all available in vector format on Brands of the World so that will save the sign company a stack of time. Calsonic you can just retype using "Nissan" font.
http://www.brandsoftheworld.com/logo/total-2
http://www.brandsoftheworld.com/logo/impul
http://www.brandsoftheworld.com/logo/nismo
Just finished off installing the dash and fixing up the interior before it's shipped off to Race Solutions tomorrow for an E85 tune.
Recently just fitted the following parts:
  • Surge tank and 2x 044's
  • In tank Walbro 400l/ph pump
  • ID2000 injectors
  • Turbosmart 1200 FPR
Will be interesting to see what it gets on the dyno :yes:
Need it all finished for a SOTS day at Wakefield next Thursday. Feel free to join me if you can :action-smiley-069:
Couple more photos with some minor progress:
1077596_10153121431870301_1319372144_o.j1149769_10153121431945301_949897148_o.jp
At this stage I'm not 100% convinced I got the colour right. In person it looks like it has a little too much colour, don't know how to describe it. Then again last time I saw it in person was years ago so what do I know.
For comparison's sake:
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
    • I must preface my comments with a general expression of ignorance. I have no specific knowledge of these NA automtaic things. I can only assume that the "steering wheel button" is for enabling the tiptronic controls. Wierd that it would even need/want a button for that... But anyway.... Was the car previously tiptronic? Did you put a new cluster in as part of all this?
    • Regardless, it doesn't seem wise especially on RBs to actually chase MBT. Timing scatter is the big one on stock CAS, even if that's fixed overshoot is worse than undershoot.
    • It's all about reducing the overall output. Reduce the source of it, you have wayyyy less to deal with in every other step and trick you play with. It's why something like a modern vehicle, so VW, Audi etc, there's thousands of tables for the ECU to calculate what it should be doing with the engine.   Why would you NOT reduce emissions the most effective way possible, when it has very minimal tradeoff, AND manufacturers are always struggling to meet the current standards.
