99 S15 Spec R JDM
Ive recently made the decision to sell my s15. Ive owned the car for the last year and had no issues with it. Only reason i'm selling is because i'm finally in a position to upgrade to a car i've always wanted.. 34gtr
I had the car checked over by State roads inspections and received a comprehensive report attesting the great condition of the car which i'm happy to show any perspective buyer. The car originally had an aftermarket front bar on it that i wasn't a fan of and also had a ducktail spoiler on it that i changed for the aero wing which required the front and rear to be resprayed. Due to the pearl white being so hard to match up and seeing as i was getting a quater of the car resprayed anyway i decided that i might aswell get the whole car resprayed and i went for Mazda paint 34k which is similar but a little brighter then the standard pearl white. I got it done at DT Panels and they did a fantastic job. Ive got before and after pictures to show the car wasnt in any sort of accident.
120,000km's
6 speed manual
Optional sunroof
Optional JDM sat nav
OEM Aero front bar
Engine mods
AM performance split dump/front pipe
Titanium cat back (muffler cut off in favor of stainless straight pipe)
High flow cat, Resonator
Turbo tech boost controller
Blitz SE front mount intercooler
ORC 409d Clutch and flywheel kit (installed 5000km's ago)
Suspension and handling mods
Powered by max coilovers (base height, camber, damper adjustable)
Cusco rear camber arms
Cusco front and rear strut braces
RDA slotted and dimpled brake rotors
QFM A1RM brake pads
17x9+18 Desmond Regamaster EVO wheels
(Fully refurbished by Wheel tech so they're immaculate)
Project MU wheel nuts
Interior mods
Yashio factory gear knob
Yashio factory gear boot
Rego untill (AUG 20 2014)
Roadworthy to be negotiated.
Im after $22500 with wheels or $20500 without.
$21500 with wheels but without aero front.
Also interested in swaps with 34GTR and cash your way ofcourse or R33 gtst and cash my way.
call or text Jason on 0401910780
Located Geelong, Victoria.
https://www.sau.com.au/forums/topic/435482-99-jdm-s15-spec-r/
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
