Hi guys, as the title suggests, I noticed the rear GTR badge on my R33 GTR was recently vandalised or something so it's a little damaged so I am thinking about replacing it with another GTR badge from another generation of GTR's.
I don't like the rear R32 GTR badge as it looks a little small, the R33 GTR one is of course designed for the R33 but I was thinking of perhaps changing it up and going with a GTR badge from either the R34 or R35. Has anyone done this and any photos? I'm not trying to turn my R33 GTR into a R34 or R35 (nor would I want to) but just thought I'd be nice to swap the rear GTR badge seeing it's damaged anyway.
Thanks guys.
R32 GTR:
R33 GTR:
R34 GTR:
R35 GTR:
Edited by Robocop2310
https://www.sau.com.au/forums/topic/464272-different-rear-gtr-badge-on-r33-gtr/
R32 GT-R is curved slightly to go with the boot. It's also colour coded.
The R33/R34 I assume are the plain ones, I got a cheap plastic one off ebay for a couple of bucks (still somewhere in the garage). They're aren't curved so won't sit on the R32 boot properly (assuming the cheap one I have is like the genuine thing).
Thanks mate. I'm assuming you know I was referring to what would look OK on my R33 GTR. I agree with you though, the R32 GTR badge is a little curved to suit the R32's boot so would probably look funny on a R33. Perhaps the same can be said about the R35 badge so I'm leaning towards either stick with another R33 GTR badge or try the R34 one as they booth look somewhat similar.
Check out this stuff:
http://www.sau.com.au/forums/index.php?/topic/462801-Custom-Billet-Badge's---Unique-To-Your-Car
I am sure that Tim will be able to make a high quality badge for you. He is creating some items for me and I have seen some of the items he has produced for other SAU people and they look fantastic.
Hey mate, Tim's work is obvious of high quality but I'm not after anything custom or aftermarket want the genuine stuff but wouldn't mind some thoughts on which type may be an alternative.
Cheers
I have an R35 GTR badge on my 32 GTR Boot lid.
I chose this emblem as it's modernised.
My 32 is not OEM colour or OEM looking so the choice for me was easy.
Your choice I feel is to stay period correct or to be different.
34 or 35. Personally I'd go 35. (I did :yes:)
Please post a photo? I'm tempted. :rolleyes:
Just checking the badges on the cars above and the white 32 looks to have the 35 badge on.
Looking at the bottom of the R to make that call.
nope different, middle line of the R on 32 is joined, whereas R35 one in the middle is pointed
  • Like 1
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
