R32 with stock RB25DET engine
Walbro 500hp Fuel Pump
Stock Turbo
Stock Injectors
Full 3" turboback exhaust
FMIC
AEM Boost controller
Xtreme HD clutch and lightened Flywheel
WOLF 3D V500
Pulled 291rwhp or 218rwkw at 13 psi
1997 R33 GTSt:
Head:
HKS 256, 264 cams
Tomei valve springs
Brand new OEM valves
Brand new OEM guides
COMETIC 1.3mm Headgasket
Bottom End:
Mahle pistons
SPOOL rods
ACL Race beaings
ARP Mains and Rod bolts
Intake:
4inch HPI pod filter
Custom 4inch intake pipe
Tube and Fin intercooler kit
Greddy plenum
Fuel:
Nismo fuel pump
Nismo 740cc injectors
Turbo and Exhaust:
Garrett GT3067.82
6BOOST manifold
Synchronic 50mm wastegate (off turbo housing)
Custom dump pipe
Fujitsubo exhaust
Ignition:
Splitfire coilpacks
ECU:
Haltech E11V2
Tuned on E85 bleeding down to 16psi.
325rwkw
Update:
Now with:
1000cc injectors
Billet rail
Twin 044s
Surge tank
SX reg
Braided and hard fuel lines
Profec B II
363rwkw@23psi/706ftlbs
Hi guys, dyno'ed yesterday,, cheers to Mat (Femno)
1993Nissan Skyline R33 GTST series 1
Mods are:
Custom turbo back exhaust
Pod
FMIC
10.5 psi
Hi-flow turbo
Walbro Gss342 fuel pump
Running on:
Stock Ecu
Standard injectors
Made 215.4Rwkw, pretty impressed
Will post up dyno sheet soon.
cheers
Ben
*UPDATE*
Ran again this morning, now running on 14.5 psi of boost.
Made 233.7RWKW
Still using stock ecu
When i had my S1 R33 GTS-T i had my car dyno'd at 372rwhp @ 15psi. Could have made more power but i only had stock internals so i didn't want to push it.
Mods:
Wolf 3d v4 Ecu
KKR 480 turbo
HKS 3.5" exhaust (front pipe to canon, KKR custom dump pipe)
Apexi pod filter kit
Greddy Profec 2 EBC
Trust FMIC
Splitfire coils
Sard FPR
Nismo 550cc Injectors ( had 740's but couldn't tune well with the wolf ecu)
HKS SSQV
Walbro fuel pump
2 way Cusco LSD
FMIC
3 inch exhaust
14psi
auto
Mobile 8000
196.8RWKW
Soon to have
GT35/40
38mm gate
side plenum
Power fc
Manual
cushion button clutch
550cc injectors
by the looks of these figures i should be hoping for 250kw+ (aiming for about 280)
Edited by beefcake4000
RB25det series 1
-freddy intake manifold
-stock turbo
-stock block
-aftermarket intake and filter
-12psi
-walbro fuel pump
-fmic and plumbing
-stock dp
-3" jvtr exhaust
-apexi safc
-q45 tb
put down 267whp and 233tq
Forged RB25det S1
256 Tomei Cams In/Exh
20 thou oversized
KKR430
pump fuel
Z32
standard injectors
standard exhaust manifold
greddy plenum
PFC
mechanical boost controller
low boost and cams not dialed in.
333.9 HP on 15 PSI
After many problems, finally starting to get on top of the build.
Latest tune was
380bhp on about 18psi.
- Stock injectors
- KKR 480
- Back to standard cams and VCT.
Final tune still to come, when all issues are resolved.
standard rb25 engine and head
HKS TO4r turbo kit (turbo has the 1.15 rear)
Vipec ecu
AVCR
HKS Front mount
850cc injectors
spit fire coil packs
HKS exhaust
044 fuel pumps x 2
14psi tune
rev limit 7500rpm
power 411.0hp - 306.5kw
the car has a 18psi tune but im not posting the number on forums to keep people from talking :D
hope my info on setup can help guide some of u boys
stay safe
Edited by GOT04
R33 RB25
Standard bottom end.
Ported and Polished Head
HKS 256/264 cams
HKS GT-RS Turbo
Front Mount
Apexi Power intake
Apexi Power FC
Nismo Fuel Pressure Regulator
Walbro Pump
Full zorst
Splitfires
Plazaman Plenum
Z32 AFM
337.1 rwhp (253rwkw) @ 1 Bar rev limited to 7000rpm - Ill scan and post dyno sheet soon
Edited by Granthem
R33 RB25
HKS 256/264 cams VCT retained
HKS GT-RS Turbo
Front Mount
Apexi Power intake
Apexi Power FC
Walbro Pump
Full zorst
Splitfires
Plazaman Plenum
Z32 AFM
Dyno graph for above post
Edited by Granthem
R33 series 2
Mods:
Hi-flowed turbo by Hypergear
3" stainless turbo back
Pod Filter
FMIC
SAFC 2
Bosch 040
Boost spikes at 14.5 n drops of to 10psi
230.3 rwkws
tuned at Boostworx, will scan results later.
loses a lil in the middle coz i need a fuel pressure reg. otherwise im happy
Nissan Cefiro:
Rb25det
Internals Standard
Ran a ACL race series VRS kit thru her
Fuel Reg
Stock Injectors
6Boost
Gt3582r
44mm Tial Wastegate
3" Straight Thru Zorst
Vipec ECU
Walbro Intank Pump
Splitfires
other things i forget....
354rwhp @17psi...
so far just aiming for something really safe and reliable shes a slider
Edited by Mayo
1996 Stagea auto awd RB25DET
76mm exhaust with split dump and no cat (still a bit restrictive as very quiet)
Stock turbo highflowed by GCG
Walbro fuel pump wired to full battery voltage.
550 DeatschWerks injectors
Z32 AFM
Nismo smic (similar in size to GTT but allegedly slightly more efficient)
Pipercross panel filter in stock airbox
GReddy adjustable exhaust cam gear (set at 3.5 deg ret so 4 deg pretty much OK)
Jaycar IEBC set at 1 bar
R32 ecu chipped by X-tune and piggybacked on to stock ecu.
Thanks to Joe (Joe's Mechanical Services) and Andy (X-Tune)
r33 rb25det, cheep stainless top mount manifold, 50mm trust wastegate, 3" turbo back exhuast with external plumed back, 440cc subaru injectors, 500hp walbro fuel pump, chinese chrome greddy style front facing pleninum, 72mm throttle body, 600x300x90 intercooler, 2.5" hot side 3" cold side
fueling
electronics
link g4 plug in skyline ecu with inbuilt map sensor
link g4 inlet air temp sensor
link g4 boost control soliniod
bee*r rev limiter (not a power gainer, just sounds wicked)
engine hardware
standard rb25det long block
chrome greddy style pleninum(nice casting, doesnt leak water)
cheep stainless top mount manifold modifyed to suit turbo
custom built td05/6 turbo
cheep 600x300x90 intercooler
2.5" hot side piping, 3" cold side
72mm alfa romeao throttle body
trust type R blow off valve
3" turbo back exhuast, no cat, 2 resonators, splits at diff in to 2x2.5" exhuasts external plumbed back
standard coils regood to stop miss fire
heat range 7 plugs gapped to .8
drivetrain
nismo 2way lsd
rb25det gearbox
jun lightweight flywheel
full face organic clutch plate
gtr pressure plate
there is probly some more i have done but i can't think of.
277kw on 16psi with out leaning on it. full boost 3700rpm(tuned for more torque and power over having boost earlier)
the next step is 19-20psi, but i will mostlikly need a new clutch and new coils.
then the 3rd step is a e20 e30 tune on 19-20psi
R33 Series 1
Power FC
3" Turbo back
TD06 20g
38mm Ext. Wastegate
Splitfire Coilpacks
HKS Twin Spark
FMIC
850cc Injectors
Walbro 255 In-tank pump
Z32
Safe initial tune on Ultimate 98
245rwkw @ approx 16psi
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
    • The thing is, once the content has been tagged we can chop and change the end result as much as we want. Its identifying the content in the first place that needs to be done regardless of the final outcome.
    • Sorry @GTSBoy I thought I'd replied here. There's a new BIG version of invision coming out soon, it might be worth waiting until that happens as it contains a lot of improved functionality for tags. My suggestion would be to add a top level page (not thread) with some info on it and then link to sub pages for various topics. We could even just start really simple with 2 or 3 pages underneath it. Those pages could just have a view (like a pre configured search result) of the tags we choose to put on it. We could have some background or an intro on each of these pages. My only issue is that while admins and mods can update the existing content to contain the tags we want, new posts can have whatever tags the author wants. That said, the reason our tags are so messy is because of that, so maybe we restrict tagging to admins/mods in edits.
