My series 3 with series 4 13b turbo
This is my series 3 rx7 with series 4 13b turbo. Have owned it for a while but got some new mags and some mods i thought id share.
EFI, fully electronic ignition, High HP fuel system, Port machined manifolds, High flow series 4 turbo (14psi), Mazfixc solid steel lightened flywheel, Exeedy heavy duty clutch, JAP performance turbo manifold, 3" mandrel bent exhaust, cold air intake with 3" K&N cone filter, custom high capacity sump, Series 4 front mount oil cooler, Series 3 5 speed gearbox.
Recent mods were the 17" apec mags, 205/40 front 235/45 rear. Microtech lt10s computer, Slotted DBA brake rotors all round, whole new clutch setup due to the last one carking itself, also have a glimmer drive pulley kit i have to put on (40mm belt with large teeth).
Very soon to come full pwr front alluminum setup (intercooler, radiator, oil cooler and 16" thermo fan), viper alarm sytem to be installed (have sitting at home) and 2 front 6" component speaker and 2 12" jl audo subs (have sitting at home). And lastly if money left over will be getting a guru torque biasing diff.
Car made 262rwhp on 13psi however i only run stock boost 8-9 psi because i dont have a boost controller. Hoping to go to the drags and get 12s once the rest of the work is done.
The fianl pic is a little sticker on the passnger window it reads. "WARNING: This car is equipped with a turbocharger. Due to possible breathing problems under heavy acceleration, all females are advised to remove any tight or constrictive clothing for safety".
Enjoy.
Other Images
Featured Images
- 8 replies
- 366 views
- 52 replies
- 4,253 views
- 270 replies
- 73,529 views
- 3 replies
- 723 views
- 2,885 replies
- 536,208 views
