Hey Guys, I understand this has been covered and believe me I have searched but anything I find, the link is no longer availible...
I want to install my Tomei Hicas lock kit this weekend but the instructions are in ne hon go...
Can someone please point me in the right direction to find english instructions or wiring diagram?
Thanks for your help!!
Todd
https://www.sau.com.au/forums/topic/128604-tomei-hicas-lock-kit/
cool.
this is rhe procedure..
start the engine and WITHIN TEN SECONDS!! turn the steering wheel 1/2 turn LEFT hten RIGHT 5 times then depress the brake pedal 5 times.
this will put hicas into a diagnostic mode.(dont drive it)
it will take a few gos to get it. its hard to do all that whithin 10 seconds lol
when its inttalised the hicass light will flash. turn the wheel left and right asnd you can see the rear turn. use this procedure for inserting the shims into the rear steering rack(they wont fit otherwise)
as far as the electrics go ??????
Thankyou VERY MUCH! This should be in the DIY/FAQ section!
^I think copyright prohibits this.^
Can someone translate this for me? Please Phunky?
As the r33 plug looks nothing like the one shown on the PDF doc, Im having trouble choosing which wires to plug into.
I fitted the lock washers last night, I used a 12v source to move the rack (those screw are sooo tiny) and wheel aligned today, the light is on but it drives like a normal car with none of that tail waggle that I had to get used to when I first drove it, I prefer it like this and when/if I ever get the wiring colour codes, I will get rid of the light, I want it working as hicas also governs the power steer and hopefully it still comes on if there is a problem (touch wood).
Well after much searching I found this on a site.
I am guessing that the signal wires A & B are the wires on the rack that read the movement of the rack, without running out and looking, i know there are 3 wires on that connector, I can get an idea of which is which, I will have a look at it tommorrow and see what happens.
I did it! The pic is a wiring diag of the setup for a R33.
Thanks to all who helped with this Al, Predator, Shane, ColGTSX, Bl4cK32, Sav man and anyone else that I Pmed :rolleyes:
Disclaimer: This worked for me it is no guarentee that it will work for anyone else.
  • 4 weeks later...
hey guys
i went with the above post picture
and i got a 96 r33 series 2
i went with the wire harness guide and installed it as pinned out on the harness but either way i look at my harness in the middle section those wires indicated arent on there
in the first picture i have showed the wire which i have spliced into
the second picture is looking at it from other side also indicating how i have wired it
cheers much help is need before my care is running as i dont wanna ruin anything
cheers
    • who can tell me what this is and why my car talks to me? i think it's hilarious. it's on my r34 right above the drivers-side storage compartment. the characters under the wrench say "inspection". every 10 or 20 startups, a voice starts talking in japanese from some speaker in this area below the dashboard. it says a few sentences then shuts off. different from the ETC card reader voice that happens every time i start the car. I've never found the speaker, i've never been able to catch the voice and translate what it says, and i've never found a forum thread that tells me how to reset the warnings. the holes in between the symbols are NOT buttons you can press to reset the warnings. anyone else have this? has the demon lord from Hereditary infected my car?!
    • Would you ever vent this bonnet or will it be unnecessary?
    • Happy new years folks! Wishing you all a successful year of money pit ownership!  So the subframe bushes are out....   Ok, who else has done that job before??  What a C U Next Tuesday of a job that is!  Be glad to not do that again in a hurry! I think I explored every option available to chop the middle section of the bushes out, most of them unsuccessfully! I tried a holesaw, die grinder, normal drill bit, air chisel, etc, etc. The true success happened by accident when I'd decided to try a step drill I spotted on the bench on the way passed.  See, there are benefits to never cleaning up after yourself! It RIPPED through so so much better than the drill bit. It has to be the skinniest one available so its small enough to fit between the inner tube and outer casing but it made easy work of it.  First one i hammered the shit out of... New method- 20250102_185506.mp4   I did the other 5 in less time than I fluffed around with the first one. With the first couple I used the cut off saw (sawsall as the yanks love to call them) to cut a break in the outer casings. Even with that they're still a prick to hammer or air chisel out.  The last few i just went rambo with the air chisel without cutting them. I over cut one of the early ones so will hit the with the mig to fill the cut then sand it off smooth.  The carnage left over-   I've also been "nesting" ie, cleaning up my babies nursery,  ie cleaning the f**king pig sty of a shed. I've got that much shit laying around it's as cluttered as my head!  Getting things put away, in boxes, on shelves, hanging off walls, all to get some working space back again.  Hopefully that keeps me motivated....
    • AFAIK does the base map for Haltech even have the 4D compensation enabled? It's been a while but when I looked at it I remember it was actually using pure TPS as one load signal and MAP for another. Seemed workable but not ideal by any stretch. A lot of people have "make the event-itis" which leads to stuff like this happening.
    • https://www.youtube.com/watch?v=qHhWelSBppY
