First you use the search button :)
You will find this feature very useful for alot of questions about your car.
In the past month there has been a plethora of threads opened about r33's and oil changes and what oil to use, some I think even include pictures.
Most use Motul Turbolight 10W40 or similar, and the oil filter is a Z145A (Ryco).
Nath
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1822804
The how to:
http://www.skylinesaustralia.com/forums/in...showtopic=10035
I used Motul 300V Chrono 10/40 - quite expensive but it held oil pressure much better than any other oil i've used before and the engine ran very quite and revved quite freely. The cheap Ryco filters are fine to use.
-rb25
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1826542
How do you say its fantastic.  Most oils are fine.  Dump it at 5000km and replace it.  Its only after years of running you will know if the oil is great or not.
Oil pressure on the stock gauge seems to be similar for most kinds of oil with my car..
It might be bs but i've noticed that different oils seem to lend different qualities to the motor - like make it run smoother and quieter, but thats just me...
Each to their own i guess, i would run a thinner oil if all i used the car for was round town work but my car gets heavy highway use and many hours stuck in peak traffic, so i wanted something that would give protection at the upper thermal range, and also with my car on 103,000km i doubt the clearances are what they used to be, so i opted for a thicker oil....in terms of protection you're right, i wont know for a while, but i do know that its working great sofar as nothing has broken yet :)
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1828554
Coz I just recently put Valoline 20w-50 XLD premium on my r33 gtst?
Arghhhhhhhhhh *Screams*
Please take the advice of the other guys and do not use cheap oil in your R33. It is worth every cent if you spend a little more each time you do an oil change.
Nath
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1829841
I reckon any semi synthetic that is from a reputable manufacturer will do the job. If you're religious with your 5000km service I wouldnt worry too much. If you extend it to 10000kms Id go full synthetic. I rather take the cheaper oil dump more often approach..probably in japan our cars were getting an oil change every 15-20k kms. 10k kms if by the book. As motors get older therre is more importance in doing the regular changes. It is all the unburnt hydrocarbons and petrol related products that get into the oil that cause further degradation of seals etc and decrease the effectiveness of the oil in lubricating.
Edited by benl1981
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1829854
I doubt any damage would be done by using thicker oil (20w-50w) but if youve got a newer engine you may as well take advantage of using higher quality thinner oils like 5-40 etc.
If youve got a bog stock rb30e with 200+ on the clock you wouldnt want to use anything other than 20-50 however due to the clearances rings etc being worn. Too thin oil will cause the motor to lose compression due to it slipping past the rings etc.
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1832330
Motul 4100 and a Ryco filter every 5,000km is all you need to know really :O
benm i will spank you if i catch you putitng turbolight in your new GTR. 4100 is a very cheap oil and is not a full synthetic oil. it is a blended oil. go at least for the 8100, but i would say use the Chrono 300V.
I've used the castrol forumla R 10W60 and personally i think it's too thick. a good full synthetic around the 10W40 area is what you want.
https://www.sau.com.au/forums/topic/100015-oil-change/#findComment-1837837
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
