Prompted by a new post regarding head torque on a RB20, I decided to test out the Search functions on the forums.
In the "Search by Keywords" box, I typed in: torque +"cylinder head" (as per the advice in the "Advanced Usage" sidebar), from 180 days and newer
then searched.
Among the threads returned, I ended up with:
"Porting RB26 Cylinder Head", by Mik, from Oct 13, 2005.
Now, be buggered if I can find both terms anywhere in that thread.
So, is the search engine so bloody finnicky, or am I just too stupid to understand how to make it work properly (if so, how should I have constructed the query?)
https://www.sau.com.au/forums/topic/100032-searching-the-forums/
yeh the search function on this forum software is severely lacking...
try:
+torque +"cylinder head"
every term you want in the search must have a + so it reads as:
find all threads that contain torque AND the term "cylinder head"
if you leave out the first plus you get
find all threads that contain torque OR the term "cylinder head"
Or you can try torque on its own
Might bring up a lot of threads, but you can skim over the pages it will return pretty quickly by thread titles.
Might take 5mins longer, but thats how i do it.
I make it an general as i can within the topic im looking for.
Cant say ive had a problem yet
I can now see why ypeople can't get anything out of <search>.
Just tried to retrieve a For Sale I put up last week. Entered my user_name in the <Filter by member name>, and specified "Last 30 days" <or newer>. Search Classifieds + all sub-forums. My thread was not among the single thread returned.
I knew that the title was "Garage Sale", so I tried both "garage" and "+garage" in the <Search by keywords> field (all the other fields as above).
On both occasions, all I got was:
"Unfortunately your search didn't return any results."
I have been posting and some are 5 miutes ahead and/or 5 minutes before others.
ie
person time of post = 12:10
my post after = 12:05
The is a glitch in the Matrix
Edited by Slide
  • 4 months later...
search dont work properly for me most of the time either
today i tried to do a search for *mines* about my gtr ecu but cME back with couldnt find anything
then after a few comments in new post a made about it a mod must have done a search and found stuff and linked it into my thread then locked the thread which i dont think is justified when the search engine is full of bugs not working properly.
link to my thread
http://www.skylinesaustralia.com/forums/in...howtopic=118215
searches i did for it included
mines
mines ecu
gtr mines ecu
all searches came back negative
this isnt the only time i have tried using the search function and it hasnt worked
Indeed i did Sam :O
link to my thread
mines
mines ecu
gtr mines ecu
I locked your thread :)
I searched using "mines"
I can 100% say its definately working, sometimes the search button is a little funny, but i just tried it again and i came up with the same results for "mines"
However, i bet you forgot the following crucial search option, and thats why it is not working for you.
You must change the Search posts from... box if you wish to search back further
The default is 30 Days...
You must change this depending on how far back you wanna go. I used 365 days
Cheers
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
