Well, this is new to me. a new forum topic. hope it doesn't get snowed under...
I just picked up my 1990 gts-4 from compliance (in Melbourne). Nice, started straight away.
Drove round the corner to put in 20L of fuel... Again, no problem starting.
Got home and couldn't re-start the thing.
It had plenty of time to cool down (if its not on boost, there is no need to leave it running to cool the turbo, right?)
Occasionally it will briefly (1/2 a second) tick over, but then it dies.
It has been suggested to me that it is fuel starvation. Fuel filter is top of the "I can do it" list. Mechanic is second (and an RWC). Is there any way I can check it? Or are there any other ideas / theories?
I just don't get why it worked before and not now. Talk about deflating expectations
And yes, I tried the search button. 'search flooding', according to the server. I don't get it - I am sure that I have seen these type of posts many a time before. Oh well, If I have transgressed, I am sure I will be told.
https://www.sau.com.au/forums/topic/100047-rb20det-wont-start/
when it doesn't start what are the symptoms you see/hear?
do the lights go dim? does it cough and splutter?
does it tound like it wants to start but simply doesnt?
do you hear the fuel pump prime when u turn to acc and on?
starter mortor turns over
most of the time nothing, and then it will splutter for a second and die.
to me it sounds like it wants to start
I can hear the fuel pump prime when I turn the ignition on
One of the warning lights comes on -
S S S
_____
left of the 'open door' light, and under the '4wd' light. I don't know what it is, and it *may* be relevant.
I get off at 2 today (home at 3), so I'll be checking it out then.
thanks
Edited by ebola
You dont have an alarm do you? My parents SS did the same thing.. would start, die, start, die.
Disconnected the battery and it worked fine after that, though it was the imoboliser doing it. Maybe check all your fuses.... thats where i'd start, then the obvious filters, etc.
Dayne
My car has no alarm, and I had already checked the fuses.
Your suggestion about the filters is close though.
The airbox was hardly connected to the turbo intake. Check the filter, knock the pipe off, engine wont start, post on SAU, look dumb, re-connect hose, clamp the thing on PROPERLEY, smooth as anything.
First bit of fun with my new car. Woo Hoo!!!!
Thanks for the suggestions though, all filed away for future reference.
you got spark right? if not id say igntion module... memba ur car needs three things.. spark air fuel.... fuel, could be ur fuel reg
spark.. make sure ur CAS is connected correctly. manual or auto?
need to give us more info dude
I meant that I got my car working. Though as usual, my statements are as clear as mud.
spark, air and fuel.
could smell the fuel (so there was some), and the fact that it would splutter for a second or two implied ignition (and compression).
I had forgotten about air.
I had checked the paper element in the air filter (needs replacing, but not urgently), and it seems the hose clamp wasn't on properly. The hose had come off the airbox. I guess I'm lucky it stayed put driving it home.
Because there was no air flow through the MAF sensor, it wasn't starting. I guess when it went for 1/2 a second the vibration of the motor being turned made it line up briefly.
Its a manual, and as it was a simple *stupid* thing, I have not taken the CAS module off to check it. RWC, rego, THEN I get to play.
Again, thanks to the people on the forum for helping.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
