what are u kiddies on about - this is a Skyline forum not a kindegarten.. can you talk intelligently in any thread, I've seen ten year olds talk with more sense. You are giving Skyline owners a bad name. Is it possible to talk about Skylines rather than who is dicking with who??
actually... i was going to bitch.. but **** it i don't care.. speak crap if you want to, i don't have to read it :D
I'll have to do it soon, but i need mine tuned up first now i've got an EBC in.. might be a few weeks till that gets done.
I think mine should be capable of a low 13... possibly even into a 12 (for inark: i meant like 12.99 :D) if i can get a dream launch.
laws gtr does 12s so i would assume that the dream launch would have to be something very special
I did say, "into a 12"... in other words... 12.9 and i would be stoked. Anyway, just going on other people's cars and mods, who knows how mine will go..
hehe..well mine will be turned into slicks soon enough the rate i'm going :D
Originally posted by predator666
yes..well if i was realistic thinking 12's then it wouldn't be a dream launch, i would just be dreaming :D I gotta get a shitload of octane booster somewhere.. where can i pick that up from?
putting in octane booster aint gonna help unless u actually advance the timing with the octane boost in there or run more boost!
The timing has been advanced previously... I'm mainly basing a low 13 based on the thread below because mine is pretty similar specs + i'd be running 12psi (like it was running on high boost before my EBC). http://www.skylinesaustralia.com/forums/sh...=&threadid=9292
Anyway, I shall hopefully get everything tuned on the dyno at drdrifts dyno day in a couple of weeks and see whether the EBC has added any rwkw before i really bother dragging.
What have you run previously insasnt? Just curious?
theres sumthing else going on with revs car i recon, otherwise he wouldnt be able to pull 104mph with those basic mods even if he got a perfect launch!
Last time i ran i had 150rwkw and only got 14.5 at 98mph, axle tramp issues so i gotta get sum pineapples before going again!
nah i recons it posible ... my car was stock as a rock stock boost stock cooler stock every thing.. hasnt been servbice for 6000 and i ran a 14.1
i reco with the mods his got i could get the same as his.. if i wasnt spining like a bitch threw 1st and 2nd i recon i could have broken into 13's and the factor that it was 28 degree didnt help either...
so i recon its possible
14.1 to 13.4 what rev got is a huge difference!
yeh but mines stock..
as in stock nothing ..
rev has done some work on it..
il do that work and il probly get da same as him..
only thing extra he has is exhaust and upgraded flywheel!
and that time was at motorplex in perth, which is a new purpose built track unlike calder which is useless without slicks, and ofcourse u cant drive either i heard from nark! :lol:
K&N panel filter inside stock airbox
* 3inch FGK cat-back exhaust (very quiet and probably more restrictive than some exhausts)
* 3 inch stainless dump pipe off the turbo 'wrapped' with DEI thermal tape to the cat. This dump does not have a sepparate wastegate screamer or feed pipe.
* Diff Cradle kit or 'pineapples' , the Whiteline kit No. KCA349.
* Ogura Lightwieght flywheel 4.8kgs.
* Ceramic puck sprung clutch and stock pressure plate
* Wrapped turbo to intercooler pipe (DEI thermal tape).
* Removed panel behind stock intercooler.
* Timing set around 20+degrees advance.
* disable the carbon canister fume feeds to the intake.
* Turbo smart bleed valve (cheap one) set to 10psi boost
* Simex 205/50 15 inch rear tyres. let them down to 19psi.
* NGK coppers ...6ES gapped to 0.7mm.
thats alot more then what i had when i ran...
i only had da pod and dats it ohh and BOV but apparently that slows u down..
i think stock GTST in good condition are able to break 13's ... on a nice cold night.. and a nice grippy track
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
