  • Replies 318
hey alien... i'm not understanding you! it IS double demerits.. till tonight actually! I know a few people that have alot to lose if they get caught just once! if you think going out... and doing illegal runs etc... is what a cruise is about, then all the best too you!
I personally am not afraid to give it a squirt everynow and then.. and there are a few people to back me up.. but its NEVER as premeditated as what you and your GTR mate plan... i can just imagine the convo.. what exactly do you guys have to prove?
I'm throwing down the gauntlet!! Bring it to WSID... you and your GTR mate... and we'll talk.. hmmkay!
And if i don't see you there... well... no comment!
GTR Glafche: Is your GTR by chance the Black R32 in Aliens signature pic?
if he is that r32, then i have to say that i dont know this clown and it's only by chance that my car was near his car B)
all im hearing is "waaa u guys are boring..." "waaaa u guys never organise illegal street racing.." "waaaaaa im wanker please be my friend.."
GTFO!
There were ppl that came on the "newcastle" cruise that caused me and Amanda to go on our own drive. Don't think they're really member's of this forum. The way they were driving on the f3 was absolutely ridiculous.
Oooooh I can go fast in a straight line on a public road. Ooooooh, I'm so f**king good.
bah.
haha this is one stupid fight... i just dont know wat to say...
next time lets just organise a cruz... a big cruz... where there will be a pack that will cruz in srtaight line in one lane and leave the other lanes for the manicas to do their own shit in
that way every1s happy =)
*lets out breath* damn blitz!!! if you'd mentioned that earlier i wouldn't have tried! lol!!!
and yeah.. no acceptance to my challenge!! maybe its cause when they street race they cheat... or maybe they can't launch so its rolling starts only... or they jump the gun!! can't hack a timeslip thats proof over everything else? hmmkay!!!
lol!! love the pic :P
and will.. comeon.. there is nothing wrong with straight line! give it the same respect you give corners! :rofl:
ok moanie y r u beein a sik bitch for?
I'm not gonna say i can beat you or nothing but I will give u a go as I have not yet been beaten byt a 33 gtst
and as for GTR Glafche... he woudlnt waste his time racing you or most ppl on this forum
12.6 seconds says you'll lose alien :rofl:
that's on standard street tyres with stock rims too.
haha sorry... mayb i'll sell the Supra or the R34 and buy a S2 as well and blow about 20gs on the engine to get high 11s and then act tough
Alien...please race Moanie, I want to hear about it,and the reason GTR Glafche woudlnt waste his time racing most ppl on this forum is because they wont "run" him on the street. Cause if he races at WSID his NFSU2 street cred points wont go up, which is a shame
Edited by Bunta
u got NO CHANCE.
yeah he would.. isnt that what he's crying about?
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
