  • Replies 67
Posted Images
Yeah, I heard about that as well. Apparantly it happened during the supercruise last night - pretty sad :D
I left before that happened though, so other then hearing about that, I had a pretty awesome day :D
I do feel sorry for the people getting pulled over at the defect station on the way down from Sydney though. There were heaps of cars in there when we passed by. It shits me how the cops/rta/epa try to profiteer from these sort of events. Fair enough, defect people for obviously dangerous things, but they were throwing the book at people yesterday for ridculous things obviously trying to do a little revenue raising.
My brother got a $500 defect for having a loud exhaust which is ridiculous as his car isn't that loud at all. Apparantly the officer shoved the microphone right under the exhaust when I thought they were supposed to be 3 feet away?
Also saw a stock looking black 33 (with Vic plates) with bonnet up getting harassed by the cops. Hope they didn't give you too much grief mate...
I went to summernats with a few mates yesterday..apart from thinking it was pretty tame as a whole we were one of the people pulled into the rta checking/defect station at marulan at about 7:45 am.
I was in an old school cressida, apart from sitting low it is bog stock..While we were in there was also a full VIP Celsior (import Lexus LS400) complete with hydraulics, R33 4dr, gtir, vn commodore, vh commodore. The gtir was going through a pretty full on EPA check, exhaust level, emissions etc..
The celsior was getting reemed for everything! Seatbelt tensioners not tensioning, wheels stick out from the guards while the hydraulics are on there lowest oh and btw the wheels were massive dish and stretched on tyres..looked hot! But it wasnt the time or place or complement the owner while 20 coppers and rta officers are going through the whooole car.
Anyways, the cressida we were in got a total fine of $420 plus 3 points. Biggest thing was that the front number plate was not displayed correctly..which is just crap, its in the standard position, just slightly bent. Also no horn, one rear number plate light not working, exhaust leak and too low to ground at one point and an apparent oil leak.
I did not see what fines and defects the other cars but we were lucky in a way we didn't have to get the EPA check done..
It was just a total revenue raising operation! Also had the sniffer dogs go through us and the car!
grrrrr :D
Only highlight of the day was seeing the R32 GTR 'TUFGTR' manage 679hp at the wheels!
Does this happen every year, or is it getting worse?
I have been to the Nats 4 times, ones with my car as a competitor. Have heard of the police, epa, rta, doing checks but never seen them, apart from the usual police presence.
The only thing that has happened was my mate, in his XA coupe, was db tested. Every year i have at least 4 friends competing in the Nats and this was the only check-up.
Well my trusty nissan pulsar hire car had no problems with the cops :wub: Glad i went that route.
Yer the crash was bad I didn't see it as we headed off at about 8 as everyone was starting to turn feral.
So did anyone see the Blue ford mercury? First time I had seen it finished and she was sweet. Managed to bring in 9 tropheys, including best paint (did i mention my brother painted it :D ) and best judged elite car.
Edited by Tragic
Yup, I think it was the year of the datto too. Never seen so many at the Summernats before!
Actually a Datto won its class in the burnout comp and also was very good in the Go-2-Whoa.
Edited by benm
The blue GTR had pumped guards (more pumped than a standard GTR), it actually didn't look too bar.
The grey TUFGTR car was at WSID about a month ago. From memory it did a high 10 / low 11sec pass.
Which blue GTR are you referring to? Pic?
TUFGTR ran an 11.2 (using a standard box) at WSID a few weeks ago. It was making 415awkw at the time. Not surprised the owner doesn't know what is done to the engine as he comes from a V8+auto drag racing background and knows very little about Japan cars. He went for a test drive at Autostyle and was hooked. :(
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
