I've been thinking... Everyone is using S13 coilovers to get low and run meatier brakes.
I'm not huge on the idea of my car needing bigger brakes, but I would like to see it sitting slightly lower. I could do this via lower springs for my DR30 struts but maybe I could swap to standard S13 struts. I know that those who have swapped to S13 coilovers have said that they need to have the coilovers set almost as high as they will go yet their Skyline still sits really low. I'd assume thats because the S13 struts are shorter?
So will standard S13 struts fit in a DR30 using the same bits as the coilover conversion, and will the R32/R33 brakes fit on a standard strut the same as on the coilover?
Good idea but the problem is. The factory coil and seat on s13 struts are to large. And will rub on your rims. You would need a huge ofset to over come this.
Id love to know what i can do. I cannot afford coilovers. ect. But id like to have some good brakes and a 30mm drop in the front.
you can get your strut towers machined to accept a platform similar to a coilover setup....but if you have a look the platform on r30's is basically as low as it can be anyway....your ONLY options are lowered springs.....and coilovers.
lowered springs with matching shocks is fine and can handle great, you just need to get a decent branded set....i would not recommend pedders(bad experience)
as for brakes i think that early magna disks are the right offset?
and use 4pot hilux calipers(or 75series Landbruisers)
I would have to ask why you want the front so low ? You do realise that you screw up all the front geometry by having it low . Caster (radius) rods and the lower control arms effictively triangulate to form a lower wishbone joined to the Macpherson strut at the ball joint . When you lower the body you also lower the suspension location points and the geometry changes .
Firstly the lower control arms need to be higher at the cross member end in order to get some negative roll camber change . If they are horizontal at rest when the body rolls the arm scribes its arc upwards and inwards pulling the strut in with it giving positive camber change instead of negative . Not good .
Secondly the front of the caster rods are set to give the nose a degree of anti dive under deceleration and braking , dropping the nose reduces this so not only is it closer to the deck - its twice as likely to plow into it .
Do yourself a favour and leave the height std , fit slightly larger anti roll bars and something like the Noltec adjustable strut tops . Set the camber neutral and dial in as much positive caster as you can - I'm running +6 and turn in is the best I've ever seen on a strut car - with 205/55 16's . The front easily outgrips the back and it wears 225/50 16's .
Cheers A .
Cheers  A .
I would very much agree with this but it all depends on how far you are willing to go with your suspension. Not much of mine is still standard including mounting positions for a lot of things. B)
Adrian I know that standard height is pretty much optimum on the DRs, and I already have my front bar scraping everywhere, but it really does look like a 4wd compared to almost every other DR30 I see on the road.
I dont want super-low, just a tad lower. Its not like I'm a modifying nut, I've had it for over 2 years now and I havent even put a boost guage on it to see what standard boost is, let alone raised the boost. Maybe I'll just leave lowriding for the Triumph... Oh yes, that shall be loooooow
Adam when I stripped the Bluebird I had 4 good 205 50 16's to use up but was eternally greatfull to go back to 205 55 16's for more height and a more compliant ride . Depending on how you see it the increase in tyre diametre did sort of fill the front arches a little more but this was not the no 1 priority . I would never deliberatly buy 50 series tyres again at least in 205's or 215's .
Most cars of that era look nose high if the rails are parallel to the ground but thats because the body slopes forward not the floor pan . Also because the front end has the engine/auxilaries and transmission to support it needs to have more travel than the rear . When there is a rapid downward surge of all the front end mass there needs to be sufficient suspension travel for the spring and damper to control it . If the car is lower generally it hits the bump stops before the spring/damper can do its job . In my opinion you don't need to lower it to get it to handle . There are plenty of $100,000 + sports minded cars out there and they dont sit close to the ground .
Just for the record any strut that has the coil spring over the damper is a "coil over" . I would not be in any hurry to use Tien etc S13 bits and the spherical strut tops are a pain in the ass . Like I said , neutral camber , lots of positive caster , zero toe and you'll run rings around the doof doof wallys with 205 rubber . Wide tyres , low height and screwed up geometry - particularly with the wrong wheel offsets - doesn't work . Highly amusing rounding up some sickmobile with a standard appearing car . The bonus is its easy to live with on a daily basis and doesn't chop tyres out . Have you cake and eat it .
Cheers A .
Edit : What width rims and aspect ratio tyres do you run ?
Edited by discopotato03
If you do the rack and pinion conversion using a bluebird crossmember and S13 control arms and S13 tie rods, then wouldn't be a good thing to use S13 hubs and coilovers geometry wise?
Josh, is the rack and pinion conversion finished and on the road?? How did you sort out steering linkage? Any comments, problems?
Also, I just spoke to Barry at Datsport. If we can get 20 people interested (including bluebird guys) they said he can make a adjustable rear crossmember to suit DR30.
Cheers
import hr31 brakes are bigger and will lower the front by 40mm (someone else said that on this forum). i think all you need is the r31 inserts the r30 strut tops and the r31 brake lines?
the calipars are alot bigger and the rotors are 280mm plus they have a floating rotorso you can swap to the larger r32/r33 and even gtr brakes later (if you need too)...
The only R30 I ever saw with a rack used Bluebird (modified) struts and cut/shut Bluebird/R30 control arms . Steering was HEAVY though it did have shorter steering arms .
I have import Bluebird cross member and power rack but the DR is going on the market after rego in a couple of weeks so wont happen with me . I would have also cut/shut the control arms to suit the respective cross member and caster rod/ball joint .
S13 geometry is different because they used larger diametre springs and have less bump travel . You may find on a Bluebird or R30 that the bump travel is insufficient and droop travel excessive . Setting a reasonable ride heigh is only half the job . You can get better geometry from nearly std bits - need adjustable caster rods .
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
