Just wondering on how to bleed the hicas on r32 gts-t. Just changed the power steering fluid, and bled the system by jacking the car up, and running the steering through slowly, but when I went for a drive the hicas is very twitchy now when driving in a straight line at 80kmh. Will it bleed itself over time (as hicas does not opperate constantly like power steering? Never used to be twitchy like this. Any help greatly appreciated.
https://www.sau.com.au/forums/topic/100123-bleeding-hicas/
I think there are 2 bleed nipples on rear rack. Might be worth a try as there could be an air lock in the system somewhere? When I replaced a pump recently - basically total system (front) had to be primed and everything was ok in rear before and after that.
But in long term, I agree with Josh.....
Edited by luckydip
https://www.sau.com.au/forums/topic/100123-bleeding-hicas/#findComment-1826067
    • Might be tricky matching the seat trim material  If your got the funds you "may" want to get the rear re-trimed as well to match the front
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
