Cost for the most part.
Theoretically stainless steel should be more durable (ie last longer), but the grade of stainless used I've found is at the 'lower end' of the scale, as it were (ie 304.....if they used something like 316L I'd be more impressed).
what if u get mild steel, and get it coated in that high temp stuff with the money u saved by not getting stainless....that'll prevent rust anyway wouldnt it?
unless you live on the beach, mild steel will last longer than you have the car for
cool, i thought it was mainly performance based results...thats why i was gonna get stainless. and was gonna have mild steel cat back. ill probably just go all mild steel now :P and maybe get it all coated
Stainless sounds different to mild too doesn't it?
stainless is louder and resonates more
mild steel has thicker walls which quiets it down
stainless steel is also prone to cracking, especially for dump/front pipes. unless you buy something good quality, which usually means it will be around double the cost of the same item in mild steel.
depending what you get and what you want. 316 stainless steel is overkill on an exhaust. 316 is what we call food grade stainless steel, we make benches and anything that comes into contact with food out of 316. why do you want a food grade exhaust system will you be eating off the muffler tip?
304 isnt as good as 316, but look at the price tag. hehe, 304 is good enough for an exhaust system. wont rust, well it can, depends on the conditions, anything metal can rust.
if you want to talk about shit stainless steel then talk about the 4xx series stainless where you can stick magnets onto it. Like what they make those stainless steel fridges and appliances out of. Thats shit quality stainless, and is mainly stainless in its appearance. As people have said stainless flows slightly better, drones, resonates more.
people also tend to forget, stainless doesnt get as soft and expand and contract as much as steell either. Any capable workshop should be able todo the same with stainless as they can with steel. Its just easier with steel. I would pick stainless, im making my exhaust for the munro out of stainless steel. Will look awesome from under the car, and just easier. You can purchase seperate bends for them, unlike steel where u have to get a shop to literally make you some 45 and 90 degree bends.
One thing i advise people not to do. Mix and match. The two steels will react with each other (electrolisis) and cause rust to begin.
Oh and i know, i work with the stuff :P
i think most exhast shops will do stainless steel, best bet would to be ring around first. Try and find an exhaust shop that specialises in stainless steel exhaust systems, as specialists usually do better custom work with the specified material as they are better setup for it
Oh and i know, i work with the stuff :)
A couple of things:
One of the principal differences between stainless steels & carbon (ordinary) steels is that stainless has a much higher coefficient of thermal expansion. Hence when heated it will expand much more than ordinary steel. That is why keeping the stuff flat when welding it is so difficult. It is for this reason that you should make the flanges that attach to the turbo from carbon steel - otherwise you can stress the housing. I have a set of HKS dumps made with carbon steel flanges & stainless pipes.
As for the grade 304 is just as good in this application as 316. 316 has a higher chrome content & is better at handling acids (Principally hydrochloric) - not a concern in out application. No point using either 316L or 304L as these only have a lower carbon content - a waste of money for our application.
Electrolisis can be a problem - but usually only if you live to about 140. There are that many different steels, aluminium & other metals in the engine bay it is usually not worth worrying about. :blink:
I could pick on so much in your post, but lets stick with this. Stainless steel can be annealed like any other steel and it actually has about twice the thermal expansion rate of carbon steel.
I'm a metallurgist by profession with, well, let's just say many years experience including specialisation in material and welding specifications for stainless steels. You'll notice I mentioned 316L specifically - there's good reason for specifying the low carbon form when welding. If you work with it you'll know why.
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
