Just fitted a temp gauge with a sensor mounted next to the pod filter, driving at night, stopping at lights it reached a max temp of 65.5 degrees, hate to think what temps i'd get being stuck in traffic in midday :D
CAI is now priority one :)
Anyone get similar temps???
https://www.sau.com.au/forums/topic/100147-the-problem-with-pod-filters/
theirs an easy solution to this, make up an alluminium shroud and place it just behind ur front bar, dont block off the radiator if u can and then run some ducting from the shroud to the front of ur pod. or perhaps just case the pod off because it sounds like ur getting heat soak
A CAI isn't much good if your pod isn't heat shielded.
While a CAI might help drop inlet temperatures once you've picked up speed, it won't do much in stop-start traffic and you'll still get some heat soak.
I've used one of those laser spot temp things, and after a fair weather session at Wakefield there's been a 15-20 degree differential between the engine side of my heat shield, and the metal ring on my pod.
This is what my setup looks like:
(The other side of the flex pipe is in the front air dam, so its directly in the airflow)
However, around town there's not much in it. While I haven't measured it properly, touching the heat shield and the pod's ring doesn't bring up a noticable difference when I get home after going to the shops.
Edited by scathing
Isaac, if you still have your Airbox, Cut a hole in the side of that for the Piping from your Pod to the Turbo, and Stick some heat proof shield stuff on the inside if you can. That may help with the heat issue. But yeh as intensevil said, it sounds like heat soak.
If you are that worried about it just swap your pod back to the factory airbox. I swapped my HKS Pod filter for a factory airbox with K&N Panel filter and couldn't notice any change at all (and neither could a dyno).
The other good thing about a factory box is that it's perfectly legal unlike an open pod filter.
Yeah i treat shielding as part of CAI, so gunna do both and measure the results.
Still have the stock airbox but no snorkel, so it pretty much would still be gulping hot hot air (remember the airbox inlet is on the engine side aswell).
It doesnt help much that my turbo doesn't have a heat shield too, might get one of those turbo bags..
i just got made up a heat shield from aluminium from bunnings covered the engine side and the top of the filter, and with the old hole from the stock cooler i ran some flexy tube stuff fromt that hole to the meshed vent in my front bar.
ben...
the temperature of the pod filter itself and air intake will be different to the temp of the air being sucked into it. of course being in the engine bay the air will be much hotter than ambient air but if your temp probe is attached to the pod filter or intake piping etc then it will be showing the surface temp rater than the air temp.
Temp sensor is mounted in the surrounding space of the pod filter, not attached to anything bar a long cable tie used to 'hold' the sensor in the airstream about 3cm back from the probe, its at least 3cm from the pod itself and probably at least 10cm from anything metal (piping, engine bay etc..) so reading is as accurate as i could make it..
i hope you didnt move your AFM with it...
If you did, therefore changing the amount of air between the AFM and intake, then your computer is reading the wrong thing that the AFM is tellin it.
cheers
nah mate, the AFM its an air flow metering device, it only measures air when its flowing through it, so it doesnt matter if you have it closer or further away from the throttle body as its still measureing the same amount of air.
hope this clears this up
after putting a POD on my car, i noticed it was smooth/quicker reving at HIGH revs, but low down is really really bad and slow... i want to go back to the factory box.
and i think a factory box with a high flow panel is perfectly good untill you start making some real high hp
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
