i plan on putting in a roll cage in my car, but i have 2 concerns regarding it
1) is there some way i can still retain use of my backseat? or is this a sacrifice i have to make do without for a cage
2) is there any way it can be fitted in the rear without being put through my parcel tray into the boot ( stereo issues)
if not then ah well ill make do without the cage but just an idea incase the car starts runnin quick times
cheers...ben.
https://www.sau.com.au/forums/topic/100172-rollcage/
1) Generally Japanese cages don’t go through the parcel self. They bolt onto the rear wheel arches, as per the pic of my cage.
2) As you can see from the pic the rear bars bolt onto the wheel arch, thus having a rear seat wouldn’t fit unless the seat was re made to fit around the bars, and then you have the issues of getting around the diagonal brace if you wanted one. Why you would I’m not sure as its illegal to carry people in the back with a cage.
Hope that helps :D
*Edit* If your running quick times you’ll need an ANDRA approved cage anyway, so I guess the above is really not relevant as you would be getting a custom one made no doubt.
Edited by Nismo_Boy
https://www.sau.com.au/forums/topic/100172-rollcage/#findComment-1826442
  • 10 months later...
yeh doesnt matter its too hard to do and still keep my interior as is...yeh i dont put people in my backseat anyways so it doesnt bother me bout that...i was gonna put a 1/2 cage in and register it as a 2 seater thats legal but again stuffs the interior...i'll just strip it out later on next year and get my uncle to weld me up a cage, run a few fast times then go back to my interior...
ben...
https://www.sau.com.au/forums/topic/100172-rollcage/#findComment-2647406
if you want to run unrestricted ETs with no cage, take a drive down to Heathcote.
ben...
https://www.sau.com.au/forums/topic/100172-rollcage/#findComment-2647900
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
    • Brakes definitely won't make him faster. They only slow you down. 😛
