grim32 Posted December 31, 2005 Share Posted December 31, 2005 just curious as to what would win in a race, i no the 4wd would have more power at the engine but if they both had the same power and torque at the wheels, and traction would there really be a difference in a quarter mile time if both setups are identical? thanks guys. Link to comment https://www.sau.com.au/forums/topic/100215-same-power/ Share on other sites More sharing options...
grim32 Posted December 31, 2005 Author Share Posted December 31, 2005 come on guys what do you think Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1827110 Share on other sites More sharing options...
RedEmblem Posted December 31, 2005 Share Posted December 31, 2005 between what? u mean a gtst 32 and gtr32? Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1827182 Share on other sites More sharing options...
dezz Posted December 31, 2005 Share Posted December 31, 2005 how is the 2wd gonna have the same amount of traction as the 4 wheel drive? Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1827184 Share on other sites More sharing options...
MANWHORE Posted January 1, 2006 Share Posted January 1, 2006 That is exactly what I was going to say. I do know what you're trying to say though. Do you mean if they both haev exactly the same amount of torque, power, and both have good tyres? The gtst will win, because the gtr is 200 kg heavier. Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1827199 Share on other sites More sharing options...
Madaz Posted January 1, 2006 Share Posted January 1, 2006 im thinking he means like the GTS-4 vs GTS-T with the same power and setups i would say the GTS-4 might win purly on a high rev launch will give it 99% traction all the way down the track Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1827487 Share on other sites More sharing options...
Mulkers Posted January 1, 2006 Share Posted January 1, 2006 GTSt v GTS4; t will win, as it is quite lighter. power is same at fly (158kw) and there is potentially less power at wheels in gts4, as more drivetrain may consume more power. my 2c Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1827622 Share on other sites More sharing options...
Madaz Posted January 1, 2006 Share Posted January 1, 2006 i believe they have more power than that taken from here 250HP and i assume its @ the wheels i will be able to tell u sum time next year when i get to a 4wd dyno as for racing ive beeten a R34 GTS-T and a 260rwkw GTO Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1827642 Share on other sites More sharing options...
Triskillion Posted January 1, 2006 Share Posted January 1, 2006 i think its clear that a car with the same power and same weight the 4wd would win but im guessing if you set up a rwd decent (even if you set the 4wd good aswell) it would be the same... Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1828409 Share on other sites More sharing options...
Madaz Posted January 1, 2006 Share Posted January 1, 2006 i think its clear that a car with the same power and same weight the 4wd would win but im guessing if you set up a rwd decent (even if you set the 4wd good aswell) it would be the same... <{POST_SNAPBACK}> 1st flaw is the R33 GTS-T is alot lighter than the GTS-4 2nd flaw R33 GTS-T cant use full boost or power to shoot off the line due to loss of traction 3rd flaw see above flaw Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1828431 Share on other sites More sharing options...
thrtytwo Posted January 1, 2006 Share Posted January 1, 2006 if u have a Gts-t and a Gts-4 the 4 will take off a bit better but the extra weight means the t will catch up and it will be fairly close in the end. Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1828444 Share on other sites More sharing options...
Madaz Posted January 2, 2006 Share Posted January 2, 2006 the 4 takes off alot better as u can do a GTR style 7grand launch Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1828540 Share on other sites More sharing options...
grim32 Posted January 3, 2006 Author Share Posted January 3, 2006 Ok i should of asked the question a bit better. Lets say we have a GTS4 and a GTST, -both cars are modified to wiegh the same -all gearbox and diff ratios are the same -both cars are governed to 100hp at the wheels -both use automatic, with lets say a 3500rpm converter -both use slicks and dont wheelspin at all just trying to say on paper if both cars are evenly matched is there and advantage using 4wd. Thanks for the response guys. Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1830532 Share on other sites More sharing options...
Mulkers Posted January 3, 2006 Share Posted January 3, 2006 32 gts4 is turbo 33 isn't. If all was equal, gts4 wins. Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1831166 Share on other sites More sharing options...
Madaz Posted January 3, 2006 Share Posted January 3, 2006 Ok i should of asked the question a bit better. Lets say we have a GTS4 and a GTST, -both cars are modified to wiegh the same -all gearbox and diff ratios are the same -both cars are governed to 100hp at the wheels -both use automatic, with lets say a 3500rpm converter -both use slicks and dont wheelspin at all just trying to say on paper if both cars are evenly matched is there and advantage using 4wd. Thanks for the response guys. <{POST_SNAPBACK}> when u come back from fantasy land let us know u sound like sum 1 talking parity from V8 super cars... see when u say same this slicks that no wheel spin it just doesnt happen cause by that logic they will cross the line @ the same time if both have 100hp both auto both weigh same both u see were im heading there is no differances to make it a race 32 gts4 is turbo33 isn't. If all was equal, gts4 wins. <{POST_SNAPBACK}> correct but mine has had a turbo fitted hence my profile << Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1831613 Share on other sites More sharing options...
kasanoff Posted January 3, 2006 Share Posted January 3, 2006 sorry to hijack... what about a rolling start (so wheelspin and traction don't really play a part)? say 2 cars, both of the same weight, and both of the same power at the wheels...but one is 2wd and the other is awd. so: 180rwkw vs 180awkw for example... obviously the awd car is making more power at the engine than the 2wd car. but after all drivetrain losses have been applied, both have the same power should both cars then be equal? effectively neck and neck? (this is all hypothetical of course - i'm just interested to hear ppls responses) Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1831997 Share on other sites More sharing options...
Duncan Posted January 3, 2006 Share Posted January 3, 2006 same torque curve, same weight, same shape, full traction = same time. Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1832039 Share on other sites More sharing options...
Madaz Posted January 3, 2006 Share Posted January 3, 2006 sorry to hijack...what about a rolling start (so wheelspin and traction don't really play a part)? say 2 cars, both of the same weight, and both of the same power at the wheels...but one is 2wd and the other is awd. so: 180rwkw vs 180awkw for example... obviously the awd car is making more power at the engine than the 2wd car. but after all drivetrain losses have been applied, both have the same power should both cars then be equal? effectively neck and neck? (this is all hypothetical of course - i'm just interested to hear ppls responses) <{POST_SNAPBACK}> i blelieve tha AWD with 280 will beet the 2wd assuming its like a 2nd gear 60kph rolling start Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1832136 Share on other sites More sharing options...
lordsnipe Posted January 3, 2006 Share Posted January 3, 2006 if they're the same weight, same power at the wheels and same torque, then how is one going to be faster than the other? but this is a stupid question anyway as you'll never have a rwd car and awd car the same weight/power/torque. there is an advantage to 4wd. it's when twisties are involved... Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1833123 Share on other sites More sharing options...
scathing Posted January 3, 2006 Share Posted January 3, 2006 same torque curve, same weight, same shape, full traction = same time. <{POST_SNAPBACK}> What Duncan said. Unless one of the two cars runs dramatically shorter gearing, there's going to be nothing in it from an ET perspective. Once you rule out 2WD's weight and drivetrain loss benefits against the 4WDs grip advantage, you're going to have to start splitting hairs elsewhere...or the cars may as well be identical. I would have hoped that this was so obvious that it went without saying, but evidently its not....... Link to comment https://www.sau.com.au/forums/topic/100215-same-power/#findComment-1833323 Share on other sites More sharing options...
