Hey people...
Just came on to saye hello, this is my ride;
1997 R33 GTST Series 2
Body Kit (www.awcinfo.com)
Intercooler
19" wheels 275/30/19 on the rear :P
Carbon fibre Wing
3" SS Zorst
And looking to improve under the bonnet.
Are there many cruses from NSW members?
and looking forward to some good posting.
l8r all
https://www.sau.com.au/forums/topic/100231-hello/
looks awesome.. Definately one of the best looking R33 gtst's out there..
How much was the kit and wheels if you don't mind me asking.
I am not sure what the kit retails for but you can find all the parts and prices at www.awcinfo.com
The wheels cost us $2300.00 including lock nuts, balance, tyres (Only Nankangs), Fitting and Wheel Alignment.
www.tempetyres.com.au
https://www.sau.com.au/forums/topic/100231-hello/#findComment-1827694
is that a one piece front bar or extra bit stuck on the original factory bar? looks so good and clean
Um, no its not the origional with a piece stuck on it!
Its a kit that came from www.awcinfo.com
if you are interested speak to Adam from Awc and he will look after you.
https://www.sau.com.au/forums/topic/100231-hello/#findComment-1827697
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
    • I initially was going to do the whole car with a block then realised, it would be a bigger monster of the job 😂 I guess that's all part of the learning process. I appreciate all that advice, I think I got a good idea on how to tackle this whole job.
    • I admire your efforts with the scuff pad.  As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling.  Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint.  Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas).  At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process.
