I finally got my car on the road after it's been sitting in the garage for a few weeks and now my brakes feel weaker. The pedal is much harder than before, not as hard as when the cars off but it is much harder than it was before and has less "feel" to it. Also now when you press the brakes you can hear a very loud squeaking from both front calipers. Brake fluid is still full.
Anyone know what could be wrong?
Thanks guys.
https://www.sau.com.au/forums/topic/100236-wierd-brakes/
I don't think its rust, there was a fair bit of rust on the discs but that came off straight away. Also that night I drove it I went through the mountains too, so I did more braking than your usual daily drive to the milkbar :P . So I guess that would cancel out rusty pads?
Any other ideas?
EDIT: In case you don't understand, the loud squeaking isn't only when your driving, it happens all the time, even when your not moving and just pressing the brakes on the spot. I can't explain it, it sort of sounds like a rusted spring being compressed.
Edited by ToF
https://www.sau.com.au/forums/topic/100236-wierd-brakes/#findComment-1827379
dude im having the EXACT same problem .. its f*kt!!! i just got all 4 pads replaced and now my car squeaking like a cuunt wen i brake!!!! and abs wanna charge me
$940 2 get it fixt... GEETTT FKT!!!! ...bbut yeh... cheaper solutions ive been told are 2 get the rotors machined... and yeh replace calipers as my front ones have seized! - jt
https://www.sau.com.au/forums/topic/100236-wierd-brakes/#findComment-1828109
  • 1 month later...
I still haven't got around to getting this fixed yet but I've now noticed something.
The brakes are normal when u first start it and drive for the frist 2 minutes, then I'm guessing when the brake fluid gets hot and the calipers get seized.
Anyone have any idea why it will only happen after a minute of driving?
Edited by ToF
https://www.sau.com.au/forums/topic/100236-wierd-brakes/#findComment-1922660
when metal heats up it expands so does the fluid.. not by much also the fluid gets thiner.. like ur slave cylinder might leak one day when its really hot.. im guessing the rubber that brings the piston back to original position within the caliper is not workin and when the caliper heats up it seizes clamped and doesnt get brought back in.. sorry forget the proper names
https://www.sau.com.au/forums/topic/100236-wierd-brakes/#findComment-1923524
I believe I am having the same problem as this too and have been told its due to sticky callipers...
found a place that rebuilds the callipers for i think $35 each for backs and $40 each for fronts..somethin like that + parts (pistons if these r gone)... these r trade prices...if ne1 needs i can give them the number of this place...i will be taking my callipers there in a weeks time
https://www.sau.com.au/forums/topic/100236-wierd-brakes/#findComment-1957115
Umm... I just went to get a quote by my local ABS centre today.
They quoted me $300 + parts for the strip and over-haul of my 2 front calipers and flush and bleeding. That's drive in and drive out.
I asked for the price if I just brought the calipers in, $88 + parts each.
Just wondering if you guys think $88 is reasonable?
https://www.sau.com.au/forums/topic/100236-wierd-brakes/#findComment-1972701
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
