Hey all
Im currently selling my S1 R33 GTS-T and am looking for a Series 2 but cant seem to find one privately that i want...
I am now looking at alternatives, such as importing.
I have a few questions...
If i do import, i have chosen Prestige Motorsports...
On their website they say that the price of the car does not include tyres, stamp duty and rego.... would an extra $2000 cover these costs on average?
Also, i am from the country, and rarely travel to Sydney, but last time i was there i seen a lot of car dealerships on Parramatta road with Skylines etc in their yards... what do you guys think of places like this? What sort of prices would i be looking at for a tidy Series 2 GTS-T from one of these dealerships? Any of those places youd like to reccommend? You must understand i cant just pop down there and have a look... but will make the trip if its worth it...
Any help would be much appreciated...
https://www.sau.com.au/forums/topic/100239-buying-another-skyline-questions/
not sure about the dealershios because im not from sydney...but ive just imported a series 2 R33 and tyres and stamp duty can be done for underl $2k...all depends on what tyres you go for, but you'll need brand new tyres for compliance.
rego including stamp duty works out to be about $1000 for me, but thats in Vic...
i belive the 2K would cover those costs aswell. and ive noticed prestige prices seem lower then others (looks dodgy, but i belive its not) i also think if you want to get a car cheaper, get them to find you one threw the auctions and not one in there stock.
im not from sydney but dealerships usual charge anywhere from 2-5k more then what you can get them threw import or private but they are meant to give you the benefit of (usauly detailed) less hassle, almost buy and drive away.
but personal id probs import, then when in the country take it to a VERY GOOD detailers so they make the car look brand new... should do the trick
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
