Hey Folks,
Over the past few days the Stag hasn't been its usual self...
The main 'obvious' thing is when the turbo is hitting full boost (spikes to 12 then sits flat at 10psi) but you havnt got your foot flat, just enough for it to hit full boost, the turbo is cutting in and out... Sought of a bumping basically. When the foot is flat to the floor it will just hit 10 psi and sit flat, doesnt cut in and out...
Now, what the hell is it? Kinda annoying me...Anything serious? Or just a minor issue? Has only been doing it since we installed the bleed valve.
Cheers Guys,
Chris
PS - Would this be solved if I were to install the Jaycar Gear? :P
https://www.sau.com.au/forums/topic/100244-stagea-questions/
Got the same idiosyncrasy (sic) on mine after I installed a Powerup MBC. It spikes to 11psi when you stab the fun flipper then it settles back to 10.
An R33 mate reckons it is b/c of the length of tube running to the MBC is too long and turbo is overboosting ( as per my setting ) before the MBC registers and actuates the wastegate.
Dont know if this is true or not, but it doesnt seem to worry it at all and I havent popped any hoses yet.
But it is all the more reason for me to get that Jaycar IEBC sooner then later.
OK Guys! More Help needed.
Right, my old man was driving my car, about 3000rpm just starting to spool hard and "Psssssttttt" kinda like a blow off valve. Didnt sound right though, so we pulled over to see whats the problem. popped the hood and gave it a rev. Turbo isnt spooling anymore! Not at all! I think I may have blown a hose somewhere given the noise. Please please help me. Cannot drive it in its current state
Cheers,
Chris
Cheers,
Chris
My first guess would be an intercooler hose has blown off, check them all.
:D cheers :D
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
