Thanks for the info mafia .. do the garrett gt3071 turb need new lines too ?? i have a stainless manifold... but i will need to get a new one for the external wastegate if i go down this path..
thats exactly right - GCG highflow is the most cheapest upgrade ($2k) and it bolts straight back on, no adjustment to oil or water lines.
2530, you'll be spending $300 on oil and water lines, and lots of time and stuffing around... I've been there and done that, pain in the ass.
If I could do it again, I'd get a high flow. But, I can't do it again..
unless the kit specifically says that the turbo will use all standard RB25 oil and water lines then yes.
ALL non RN25 turbos need new water and oil lines, except for the kits the specify that they will use the existing factor ones - which are rare as f**k.
i thought i would quickly check with yall first...
i have a 33 with ems cooler exhaust new turbo manifold etc..
and want to upgrade my turbo... i have decided on a Garrett gt3071 with .63 exhaust and with an internal wastegate....
does this all sound like a good setup ?
Cheers thanks for any feedback
I know a couple of people who have fitted these 3071r .63's to SR20DETS and they suffer from really bad boost creep. One of them is having the internal wastegate modified (enlarged) to try to alleviate the problem.
surely you have learnt something in the last 2 pages of advice and previous topics in the forced induction section.
cheap turbo's are cheap for a reason
ebay turbo's are a no no
mystery (unknown spec) old school t04 combos are lag monsters usually
what do you call a laggy turbo?
one that comes on at 3000?
one that comes on at 3500?
one that comes on at 4000?
one that comes on at 4500?
one that comes on at 5000?
hehe thanks paul i know you get what you pay for !
so a 2530 hks would be a good upgrade on mid to high boost ?? compared to the 3071 ?
  • 4 weeks later...
The GT-RS kit, for what it's worth, was a pretty easy thing to install.
Turbo bolts up to the existing manifold and exhaust no probs.
New oil and water lines need to be used (come with the kit) and are also pretty easy, with the exception of the water line at the back of the engine block which is a b*tch to get to.
It's a solid day's work, but will net you 230-260rwkw on an RB25.
Worth considering for what you say your goals are. I imagine they would be pretty responsive on an RB20, as plenty of the SR20 guys use them aswell.
The GCG Hiflows (RB25) all seem to be getting similar power figures.
Edited by Beeble
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
    • If you do make them, im sure you would have a number of buyers.. Every GTR I've been in have rattly door windows
