My car either idles at 2000rpm or it goes up and down between 1000-2000rpm very quickly.
Any ideas what the problem maybe?
Ive done the obvious things like change plugs/ swap coils with a mate/ adjusted tps etc but ive still got a problem :blink:
Thanks in advance.
https://www.sau.com.au/forums/topic/100274-idle-at-2000rpm/
you cant adjust the timing of the idle in the powerfc, ie: editing load point 1x1 and adjusting the timing there. you can change the idle rpm. do you have access to datalogit? you could get someone to save your tune and do a full reset and let it learn the idle again
https://www.sau.com.au/forums/topic/100274-idle-at-2000rpm/#findComment-1827815
I meant the timing through settings/ ing/inj. Not changing it on the ignition map.
Ive tried initializing it aswell with no luck.
One thing I have noticed though is if I drive it gently it slowly gets better (2 hours of driving) But as soon as I hit the rev limiter it plays up again.
https://www.sau.com.au/forums/topic/100274-idle-at-2000rpm/#findComment-1827834
i had this problem with my R32 i tried:
AFM-didnt work
AAC valve cleaned out-didnt work
Cleaned out throttle-didnt work
What i did was i got a second hand part (tpp unit i think, not sure)
Anyway, Its located on the side of the throttle butterfly as you look at the engine from the front of the car. a black box with two clips coming out if it.
First to see if its the problem start the car, disconect the plug that you can see easily(on the right side of the box as you look straight on to it) ur revs should clam down but not totally fix itself. if this happens thats ur problem. thats how i fixed mine.
Water usually gets into this black box (sorry about the name of it i just cant remember it)
Hope it helps.
https://www.sau.com.au/forums/topic/100274-idle-at-2000rpm/#findComment-1827899
Nothing to do with the tps.
On the R32's its located below the throttle body on top of the inlet manifold... Has two hoses going in to it... On cold idle it opens up raising the rpm. Sometimes the spring flicks off and it stays open all the time holding rpm up even when warm.
https://www.sau.com.au/forums/topic/100274-idle-at-2000rpm/#findComment-1827928
Just cleaned the air reg and it didnt make a difference. I also tried bypassing it (same way my old setup was with out all the idle junk) and it still revs to the moon.
It just revs up and down between 1000-2000rpm.
Paul I think i do it right? Let it idle for 10mins, then switch on a/c for 10mins then the rear dimister?
I wish I had a holden....
https://www.sau.com.au/forums/topic/100274-idle-at-2000rpm/#findComment-1828016
Did you pull it apart and ensure the spring was connected?
I set my pfc idle by doing the following....
Plug in the pfc.. :blink:
Disconnect the AAC plug. Adjust idle to as close as possible to the value within the pfc for a/c off.
Connect the aac plug. init the pfc. Send it through its learn process... Perfect idle. :P
Be sure the TPS is set to ~.46v
Edited by Cubes
https://www.sau.com.au/forums/topic/100274-idle-at-2000rpm/#findComment-1828023
Yep and gave it a clean with CRC.
I just took a look on a 33 workshop manual and it says that the opening should be 3/4 open but mines 3/4 closed.
edit: ok thanks il give it a try like you said in the moring. I dont think the neighbours are to happy with me at the moment :blink:
Thanks again.
Edited by 33SOM
https://www.sau.com.au/forums/topic/100274-idle-at-2000rpm/#findComment-1828045
Thanks again.
Check to see if its flopping around?
https://www.sau.com.au/forums/topic/100274-idle-at-2000rpm/#findComment-1828102
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
