Hey guys
OK I've got a week off work now and thought I'd use it to organise the GT-R to get through Regency. It has to go for a full inspection because it doesn't have a compliance plate, but it has been complied, and was registered in NSW before I bought it.
So luckily the car is pretty much dead stock, but my issue is that I have to put a stock exhaust on I reckon to get it through, not because its noisy, but because it's a full turbo back.
Does anyone have a stock exhaust lying around for a R32 GT-R that I could borrow/buy for the inspection and what about a good place to fit it and take off after it's gone through? I don't have a booking for Regency set yet as I wanted to sort this exhaust out first.
Any ideas on how much $$$ a stockie would cost me and fitment at a workshop?
Cheers
https://www.sau.com.au/forums/topic/100275-gotta-put-the-gtr-through-regency/
  • Replies 58
It's not illegal to have a modified exhaust, so long as
a ) it retains the cat and
b ) it's noise levels comply with ADR's.
I already called regency about it, that's what they told me. It does have to be the standard cat though. They're unlikely to hoist my car up and see that the cat is slightly larger than normal, but you owning an import, (especially a mighty GTR), they will probably try to find reason to not pass it.
It would be cheaper and better in the long run to just have a stock cat put in there, if you don't have one, rather than replacing the entire exhaust. Just get them to test the noise level when you get the cat installed. If it's too loud, add a resonator, or replace the muffler. That way your exhaust will be street legal and you have one less reason to be defected in the future.
Of course call regency first to make sure that the car can be complied with a modified exhaust - my car is australian delivered, so the rules may be different.
Edited by doommachine
Ahh ok, I thought it was illegal to modify an exhaust before the cat, but if that's what Regency told you, I might not have to do anything to get it through.
I haven't looked under the car for more than a few seconds, it has what looks like a cat, but I'd be fairly certain its not the stock one. It smells like its running rich, because of that my mate reckons its a pre-silencer. I should probably have a closer look.
I'm pretty sure noise isn't an issue, it has a muffler, not like a milo tin 5 incher hehe.
EDIT - forgot to ask if any cat can be fitted to a 3 inch exhaust or do I have to source a R32 one?
Edited by slimjim
I can almost GUARANTEE if it is an aftermarket exhaust it will be too loud IF they test it.
You'd be surprised at just how quiet the limit really is.
Best bet would be to get hold of a standard exhaust if you can.
If it's illegal to mod the exhaust before the cat, then lots of V8's need to be defected for extractors :).
Anyway, like I said, borrowing an exhaust is a bandaid fix. Really, you should try to get the car modified to be legal, as is, for daily driving. It's a GTR skyline - cop bait, unfortunately. Look how many people have gotten exhaust/EPA defects on this forum, and their exhaust has been tested at an inspection station and passed.
Just make sure you have a cat and get it tested for noise - any good exhaust shop will be able to do it. They will also be able to make it quieter for you.
No point borrowing these items cos when you get defected again(It may happen) then you still have your stockie stuff to put back on again......just like everyone else.
There is no point getting it made to be legal because the Transort SA "legal mods" are sh1t!!! unless you mod it hard and get it engineered!
Grab some thinish sheet metal and cut it to suit the rear mufflers flange. Drill some largish holes and slip it inbetween the two flanges. Should make it nice and quiet.
Dont boot it. :)
Edited by Cubes
Dont boot it. :)
True to that but don't keep it in, only put it in the day/night before and take out straight away, as it would be restricting the flow a little!
The legal noise limit for a six cylinder engine is <90 db at 3200 rpm. Using steel wool will work but make sure it doesn't come out when getting tested (guy from Regency told me this had happened).
I used a baffle plate to get through. It can be a lot of work trying to source a stock exhaust system.
I'm not exacrly sure ( it's been several years now since being pulled over by an over zealeous sargent at eliz ) and was tested at the road side with the mic directly behind the exhuast at a steady 3500rpm which is illegal and foriegn to how cars are adr tested!But my point being is that our car came in a couple of db under the required limit for a late model skyline (each limit is model specific ) it had a local made dump pipe high flow american race cat,a 4" dia resonator and the muffler that the car came to aus with (jasma). So it is possible to have your cake and eat it to, but a word of warning several of the exhaust makers (local ) have a reputation for constantly being over this limit!
Regards,
SKYLINE...(kym) B)
Limit is 90dB for all cars manufactured after 1983.
Exhaust Noise
The exhaust systems on vehicles manufactured on or after 1st January, 1974 must at the time of first registration
comply with ADR 28 - Motor Vehicle Noise.
In service all vehicles must comply with the Road Traffic (Vehicle Standards) Rules 1999 Part 10 Division 3 – Noise Emissions.
For passenger cars, derivates and panel vans manufactured on or after 1 January 1983 the stationary noise level when tested must not exceed 90 dB(A).
Passenger cars, derivates and panel vans manufactured before 1 January 1983 the stationary noise level when tested must not exceed 96 dB(A).
Yes, 90 dB is quiet, I can't imagine how high the reading on most exhausts out there would be!
But I'm a fan of the exhaust that's on the GTR at the moment, not entirely sure of the brand, but has an excellent note, no drone, I'm pretty sure it wouldn't raise too much attention from the cops when it goes back on after Regency (fingers crossed) :blink:
i thought if the car was already complianced and registered in a different state all it needed to go in for is a VIN and chasis check..... my mate just bought an r33 gtst with an exhaust that was definitly louder than 90 dB at that rev range and his went straight through!
Yeah. Mine didn't pass because for some stupid reason, it doesn't have a compliance plate anywhere on the car. Just a NSW Modification plate, which isn't worth anything over here.
So because of that I have to get a full roadworthy, then I guess I get exemption from a comp. plate or they give me one or something. Either way I just wanna get the damn thing on the road!
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
