A very Shinny blue R32 Skyline?
Didnt get the chance to take down the plates or see the front to see it if had a body kit etc..
It had been resprayed in a very glossy looking dark electric blue (darker than the S15 and N15 SSS) and 5spoke 17's
Driving around in Parramatta today..
Does anybody know of / seen / know if the person is a member?
The reason i ask is the car had a 4SALE sign on the back window!
Any help would be appriciated, thanks guys.
https://www.sau.com.au/forums/topic/10031-who-owns/
if it is the same one im thinking of.. it was for sale a couple weeks ago in the tradingpost. and around august last year too. i know because i went to have a look at it with my friend.
Nissan Skyline R32, 1992 model, full GTR body-kit, blow-off valve, 18in rays engineering, sports exhaust, lowered, four wheel steering, full options, registered 08/2003, $17000 or near offer, ANJ-71G WESTMEAD 02-9613 0219
https://www.sau.com.au/forums/topic/10031-who-owns/#findComment-156330
Originally posted by NI5MO
hahaahaa farq off porgie!
thanks for the help nissanpower, not sure if it had 18's but could be the one, i'll ring it and see, was a nice looking car...
what did u think of it, you said you went and saw it?
worth looking at, tell us all you remember bout it!
it could be a new owner now since i went and had a look at it last year in granville.
it had 18" volk rims, gtr wing, gts sideskirt rear pod, type m front bar all sprayed in a deep navy colour. big Ms air filter.. kakimoto exhaust.. alpine v12 amp.. thats about all i can remember.. probably a steering wheel too and around 70ks on it.
this guy was a 'sick habibi' too..took us for a spin and canned it down a small busy road flat shifting through every gear gettin it veryy sideways.
i saw the car again on the hume highway weeks ago with for sale written on the rear quarter windows..
https://www.sau.com.au/forums/topic/10031-who-owns/#findComment-157535
haha u guys crack me up
I have a need for power and my current ride isnt fulfilling those needs even thou i like it..
thanks for that nissanpower sounds like one i'd steer clear from, still it looked very very nice.. pitty
on that note lol does anyone know of a Wine Red R32 that drives down Victoria Road and turns onto Church St (heading towards homebush) got R33 mags i think, rear pods, side skirts, lowered, zorst, and some custom made front bar with WRX style Fig lights
one of the nicest 32's i've seen round
https://www.sau.com.au/forums/topic/10031-who-owns/#findComment-157592
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
