Hows it goin everyone. I got my GFB turbo bleed valve installed a couple of days ago, and as all you guys from melbourne would know it was around 40 degrees. I set it to 10psi and everything was fine, it was holding on 10psi up until redline.
Come yesterday when melbournes temprature droped quite a bit (dunno how much but i had a jumper on yesterday?) I got in the car to drive to a mates and when i stepped on it it spiked to about 13 or 14psi. This kind of pissed me off because what I think it means is that each time the whether changes I will need to pop my bonnet and adjust the boost ;)
Does this happen to just me? So ill advise all you guys who wanna boost your cars, dont go cheap like i did and just get an electronic boost controller from the start! ;) lol
https://www.sau.com.au/forums/topic/100337-bleed-valves-are-st/
GFB Bleed Valves aren't known to be the best and defintely spike decent amounts.... ;)
If you got a decent one (ie the cheap one we talk about on here), you wouldn't have those sorta issues.
Also, it's always best to set your boost level on a cold night... of course you're going to run a decent whack more boost on a cold night compared to the 40 degree day ;)
/bleed valve defense
the boost will always change,considering the weather conditions.it doesnt matter what boost controller you have, the car will always be much more likely to hit a higher boost on a very cold day in comparison to a hot day were the boost will not be as likley to spike.
I got a GFB Bleed Valve and Set it to 8 PSI due to my car being stock and the boost solinoid broken, mine has not spiked and holds pressure perfectly all the time. I know they GFB Bleed Valves are good when you get a good one and crap when you get a bad one, due to friends buying one after I did (dont you hate being the guinea pig).
Chris
