This is a good thread so i'm jumping on (btw: some good state posts should be moved to the aussie wide areas!).
My intercooler fitted to mine is a HKS 600x302x65 with 3" pipes and at the moment i'm just running the standard turbo with about 12psi. I will prolly crank this up on next dyno tune to 13-14psi because i should be able to run that fairly safetly with this sized big cooler because of the increased flow correct? I have a Profec B so i'm also hoping boost spike will be very low. Although i hear after 12psi the standard turbo looses efficiency and each extra psi may only give a slight power difference. So really I'm maxing out at about 190rwkw (shall be dynoed again next week)
Its hard to get some concrete figures on this (did a lot of searching on the web!), but a cooler of the size of mine is rated at about 400-500hp ? Now i'm just wondering what i should I should do next. Do I:
a) keep current cooler based on the fact that i will soonish (this year) install a bigger turbo. Will it be match for say 250rwkw ? too big still, too small?
B) sell the HKS (because it is worth a fair bit compared to many) and go for an i/c more suited to my needs, and put the difference to a turbo upgrade?
In the future I am planning on probably running a GT2530. My goal is around 230-240rwkw without having to go too stupid replacing cams, rods, pistons, etc right away.
Really my goal is a good streeter (it is a daily driver afterall) with emphasis on quick response from 0-100km/hr without too much hope of throwing pistons, cracking rings, etc.
Hmmm..maybe i'm asking all too much over a forum but some feedback could be good on what i should do would be great..
  • Replies 130
I'd keep the current cooler, but to get 250 rear wheel kilowatts I think you'll need the bigger turbo, plus aftermarket ecu, uprated fuel system (fuel pump, bigger injectors) and you'd be close. You might have to get a thicker head gasket to drop compression to run higher boost with no detonation which will make bottom end torque suffer. The trust 600x244x76 cooler will support 450-500hp, so your HKS shouldnt have any problems with 250kw @ wheels. Go for the HKS GT2540 over the GT2530.
GT2530 is meant to have quicker low down response and power - unless you are running massive boost (20psi+) the GT2530 is meant to be a better option from what I would want it for?? There's a big thread in the performance forums of GT2530 vs GT2540 - each has their own advantages and disadvantages.
Yup, PowerFC would be on the list before the turbo, and i already have a Bosch fuel pump ready to go. Injectors not too sure but they would be a more a wait thing to see thing as they're expensive. So yeah, maybe i am better off keeping the cooler, as at the moment i'm just a bit bothered by the current lag (its not massive, but noticeable).
Predator666,
you have raised an interesting issue here...
The HKS 2530 is rated to a little over 300HP, the 2535 is 340HP , the 2540 is 350HP, the 2540R is 380HP.
Most would not argue that the 2530 is a bigger turbo than stock and is considered an 'upgrade'. So when people go around claiming 200rwkw, I assume this to equate to over 300HP @ motor (in fact 180rwkw given the right sort of losses is about 300HP). IF this is the case why buy a HKS 2530?
Well for starters the 2530 IS a bigger flowing turbo than stock and does make a 'REAL' 300 or so flywheel horsepower.
If that is the turbo you are aiming for then a 500HP intercooler is a dumb idea. ie: 500HP intercooler for a 500HP turbo and a 500HP ported head and camshaft selection.
Either: 1) get the right sized intercooler for the upgrade to a HKS 2530
OR
2) get a HKS 2835 or GT3037 and so on to match up with the intercooler.
Anything else is half-arsed but, none the less will go better than stock, just no-where near as good as a proper match. And I mean NO WHERE NEAR AS GOOD not just a little better.
From what ive heard of the GT2540, it appears to have an imbalance between exhaust housing and turbine size. It seems the exhaust housing is smaller than you would expect for a turbine of its size. I presume this could create greater exhaust temps and a slightly lower efficency overall?
From all reports the GT2530 is a much more balanced unit, while overall being smaller. I suppose it depends on the power your looking for.
Id be happy with a 30. Hell, id be over the moon, anyone got one to donate, kidding :D
As for your injector claims Rob, ive been told from reliable sources the stock RB20DET injectors are good for 300 ish hp, i doubt the RB25DET would be any different.
Red17
300HP @ the motor, the flow of the turbo is always rated in engine power.
Hence why I don't have alot of time for peoples dyno figure claims when they back-figure them to relate to stupid engine power claims. Fortunately most of the same people can't produce good 1/4 times either.
rob77,
The stock injectors can easily handle 300rwhp if used in conjuction with a fuel pressure reg. If upping the turbo size significantly then I would also do injectors, not point running them close to full duty cycle.
See'ya:burnout:
The turbo is rated to 'flow' a certain amount of HP worth of air at a standard temperature and pressure. If the temp is lower etc the power can be a bit higher and visa versa. Other variables can allow a greater power to be developed from the same volume of air too.
Coming back to the HKS 2835, they are rated upto 480PS odd depending on the turbo specs. I'd say that it was a big spec 480PS item. What does the article say?
Sorry I read the article wrong... here's the quote; "probably the most popular option is the HKS 2835 Pro bolt on kit, rated at 370ps and capable of a bit more. For more headroom again, a unique option is the GT2837R from Power House Amuse.... The GT2837R is based on a Garret GT28 core, with a simularly sized exhaust housing to the HKS 2835 Pro, but with a larger compressor, which is simular to the infamous HKS 3037...." With std adaptor and manifold pipes the Chaser made 400ps on the dynopak dyno @ 1bar, 435ps @ 1.2bar and 455ps @ 1.3bar. Sounds like a fairly beasty turbo... and its a garret not a HKS ;)
Steve, I'm not going to get into the arguement about garret and hks. Yes garret make turbo's for hks, but some of the garret turbo's will not give the same results as a hks unit (such as the hks 2540's) and simularly most garret parts will not fit a hks unit. Personally I'd go a hks unit over the garret, but its a question of costs.
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
