My First Skyline's guide to changing your oil and oil filter in an R33.
Guys, after our little talk on the washer the other day. What does eveything use ?
Fibre or Copper ? I have both available but fibre just seems to be the way to go. I previuosly had what looks to be a rubber o-ring which has lasted the distance but not sure if I should be using rubber or not due to heat of the sump.
Any ideas ?
I just did the oil again... and I thought it might be time to change the sump washer, so I bought some fibre ones... anyway, pulled it out, copper washer looked okay, so decided to use that again, and put some of that thin white sealant tape around the thread... so it should be fine.
i just had my oil changed in my 33, by the 'local mechanic', who change the oil (helix ultra synthetic) and the filter Ryco z145a.
i wasnt really happy when he revved the engine at 3000rpm, via the cable in the engine bay, for 10 seconds, so that he could actually take a second reading, which was on 'full' luckily.
i think that it is bad to rev the engine at 3000rpm, when the oil filter is brand new and had not been primed (oil filled before putting on), because maybe there is a space in time when the oil pressure is low as it is filing up the filter (which at my guess is about 400mL), so therefore perhaps there is limited oil and starvation in the upper cylinders when the pistons are flyn up and down at great rate....but i suppose 3000rpm is not all that high. AM I TOO PARANOID, or does this technique suck????
I only got the mechanic to do the job as my 'warranty book' had to be stamped...otherwise i ll do it myself.
If you want to do something right...do it your self.,, is the saying, (as long as u know what u are doing).
Nah, you're not being paranoid. He probably does it that way because the quicker it's done, the quicker he can have smoko, or get onto the next job. You're just worrying about the safety of your car, which you paid for, and not the mechanic. Next time, do the oil yourself, let it drain in when you put the first lot in, let it settle, turn on the engine and let it idle until the oil pressure light goes out... then turn it off, top up and then go for a 10 minute drive.
here something to think about.... i was at BIG W, comparing Z145A's and i noticed that the Valvoline for 9$ was exactly the same as the $3.95 cheaper brand...forget the name, but was in a black box, bottom shelf.... one of those brands which you never heard of,...
i actually compared the outside casing, the hole size, the way the insides are pressed together, the inside of the filter material, you can see the holes and inside guts when you look in the light...and let me tell you guys...absolutely exact,,,,... made in PRC....peoples republic of china....the only difference was the colour...this cheap one was black.... it's funny becuae i remembered that the valvoline used to be a korean product a few years back when i drove a charade.
anyway, i compared the ryco, and there is nothing like it. In the inside the holes are cut differently, and they are more like 'slits', heaps of them, rather than holes. Cost 12$....
I also looked at a 'cooper' brand, and there is no clones, made in korea, sealed with plastic, looks good too.
anyway, somehting to think about.
I've re-used my copper sump plug gasket a couple of times now. It had a bit of a ridge on it, but i sanded it back with some emery. Starting off with coarse grade and progressing to smoother, and it now looks pretty much brand new. It doesn't leak at all.
I prefer copper, I've had bad experiences with fibre washers. They get worn/chipped with age. Re-using my copper washer wasn't me just being cheap, it was mostly due to the hassle of that I NEVER remember to buy one when I buy oil :) So it just saves another trip to the shop in someone else's car, assuming I'm doing the change during office hours.
  • 3 weeks later...
We need filter pics!
I did mine, though when putting in the new oil, i expected it to overflow when it had enough. It swallowed all 5 liters, and when putting the old shit back into the bottle, it came to 4.3l...some ppl say 4.5l for an rb20....but hhmm...think i might go check the dipstick.
Guest RedLineGTR
they say 4.5lt for most skylines...but remember that their is still oil that is left in the engine...so anything from 4.2-4.4lt should be perfect. If you want it always on full put no more than 4.5 lt
  • 1 year later...
  • 4 weeks later...
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
