hey dudez
got a problem with my r32 gtst
yesterday at about lunch time, i had driven it for about an hour, just normal driving.
didnt drive it until about 9:30 pm. goto start up and it idles at about 1500rpm
goto drive it, it wont rev above 2500rpm, and when it hits 2500rpm, its like it hits the limiter, or like a fuel cut...but when i put my foot on the clutch it will rev, and the problem seemed to go away and i could drive home
played around with it for 20 mins and it seemed to be ok after i put my foot on the clutch and revved it.
drove home on the freeway and everything was fine until i put my foot down in 5th to overtake someone and it just coughed and spluttered and it was ok then i tried again and it just died in the arse and stopped, but it didnt stall.......
pulled over and revved it again, and everthing was ok, it would drive normally and wouldnt splutter or struggle
it did the problem again as i got off the freeway near my house.
now i have to drive my 31 again...it just isnt the same....
any help would be appreciated
cheers
https://www.sau.com.au/forums/topic/100394-idle-problemshelp/
hey dudez
cheers
no one can help me???? im desperate to get it working.....
I had sorta problems like that with my GTR when i first got it. Ended up being a f**ked airflow metre. Sounds like yours is going in and out of being f**ked, like mine would, i think its age and heat. Unplug your airflow metre, and rev it, it should hit rev limiter at 2500 cause its in a safe mode. Might not be the problem, but it just sounds like it, also check your o2 sensor, it can cause problems too, just if your airflow metre is out, would be a good idea to check or replace your o2 sensor. Hope this can maybe help
Cheers
ok...pulled the afm out, found only one screw holding the plug in....put three more in.
plugged everything back together, still not revving over 2500rpm
pulled apart again....checked all the cooler pipes etc...couldnt see and split hoses, but couldnt see the pipes that actually go into the cooler..maybe they are split or loose there.....
also found that my rear muffler is totally f*kd....all the internals spat out....could this be the problem also???
i midas well change the exhaust but dont know what size or wateva....3" turbo back with hi-flow cat? how big of a muffler
cheers guys.....
cheers guys.....
No revs above 2500RPM = bad AFM.
Yeah, if the AFM is stuffed, it will not rev over 2500rpm (cuts fuel).
Plus it will be running limp home maps which are really rich, because it can't detect actual airflow due to the afm not working, so it will run like a bag of shit.
A quick check that will confirm this 100% is running the diagnostic mode to show fault codes on the engine warning light.
Edited by RB30-POWER
  • 1 month later...
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
