Hey All,
I have been a member of SAU for only a short time and have been wanting to come out on a Friday night run for a while. Anyway I thought I would see if anyone was up for a cruise this coming friday? I noticed that the last one had went from the Chatswood Chase Carpark, so might as well do the same again, if anyone has a better suggestion then please let me know!
Lets have a show of hands, it would be great to meet some of you!
Details:
Time: 8:00pm meet for an 8:30pm departure
Meet: Chatswood Chase Carpark - Lower level (Entrance off Victoria Ave)
Destination: Palm Beach along the Beaches with a stop for Pizza or the like in Newport.
Hope some of you can come along...
Cheers,
Robbie
Edited by DRFTD_32
https://www.sau.com.au/forums/topic/100404-friday-night-cruise-060106/
  • Replies 202
Posted Images
From Cherrybrook
1) Get on Castle Hill Road in direction going away from Castle Hill
2) Go under tunnel that bends right and leads to Pennant Hills Road
3) Take a left at Copeland Road
4) Take a right at very end of Copeland Road to get onto Beecroft Road.
5) Follow Beecroft Road until it becomes Epping Road
6) Continue on Epping Road
7) Take a left at Mowbray Road
8) Follow Mowbray Road all the way to Chatswood.
I drive from Cherrybrook to Chatswood nearly everyday and this is the quickest way short of taking the toll M2.
