a friend of mine lives in SA and has been defected for the lowering of her car.
can anyone tell me the laws because people in her area dont seem to know a damn thing about them.
where is the officer meant to be measuring the ride height from?
are there ways to get out of it?
are there any workshops near lincoln (i think thats where shes from) that can do a decent job on performance cars?
thanks guys.
Edited by SECUR1TY
https://www.sau.com.au/forums/topic/100416-defected/
The one occasion I have had a car defected, too low was one of the things listed.
The officer involved provided me with the legal measurements for my car when he issued the notice.
Cars have "eyebrow height" requirements as well as ground clearance requirements. Transport SA would be the people to contact for the measurements for the type of car.
Eyebrow height is the distance from the centre of the wheel to the guard.
Hope this has been useful.
https://www.sau.com.au/forums/topic/100416-defected/#findComment-1830826
get here to call regency park and ask what the _exact_ eyebrow height is for her model of car - they are all different.
Then it's just a matter of getting some new springs most likely - why does a n 89 prelude need a performance shop if you don't mind me asking? If it's something special and has a lot of modified bits and pieces, then that will cause a lot of problems as well :\
https://www.sau.com.au/forums/topic/100416-defected/#findComment-1832283
mechanics in her area arent familiar with her car so thats why she needs someone who knows what theyre doing.
ill tell her about that regency park thing.
thanks for everyones help!
Edited by SECUR1TY
https://www.sau.com.au/forums/topic/100416-defected/#findComment-1832326
I think I remember reading somewhere in the RTA reports that you can drop 2" on standard ride height, that might be the go. The problem is, as soon as you put big wheels on a car, it looks like a truck on stock springs. So you either have to use smaller wheels, have it looking like an off-roader, or have it defectably low. ;)
https://www.sau.com.au/forums/topic/100416-defected/#findComment-1833970
did she get defected at glenelg on the weekend?
yeah i saw that defect station drove straight through it :)
guy in a blue vl in front of me wasnt so lucky he had internationals lowered(dumped
actually) and rb## turbs. as i was going around the corner a cop was lifting his bonnet,
hope had had an engineers report otherwise DAMN!!!
trust the cops to ruin everyones day and such a nice day too! :O
https://www.sau.com.au/forums/topic/100416-defected/#findComment-1838285
thanks guys.
https://www.sau.com.au/forums/topic/100416-defected/#findComment-1838613
Hey guys I got defected recently for my car being too low 33cm from the ground at the front and 32cm fromthe bottom.... and to add insult to injury it was on my driveway.... anyways long story short to avoid getting defected for being too low the front and rears need to be 360mm from the ground to the centre of the wheel...hope this helps as regency is a pain in the ar$# to get through.
https://www.sau.com.au/forums/topic/100416-defected/#findComment-1838626
I think I remember reading somewhere in the RTA reports that you can drop 2" on standard ride height, that might be the go. The problem is, as soon as you put big wheels on a car, it looks like a truck on stock springs. So you either have to use smaller wheels, have it looking like an off-roader, or have it defectably low.  :)
changing rim and trye size has no impact on the hight from the center of the Hub to the top of ur wheel arch
for a R33 GTS-T
front 330mm (might be maximum)
rear 330mm (might be maximum)
***EDIT***
mine sits @
front 360mm
rear 350mm
Front
Rear
i hope this helps
did ur friend keep her orriginal springs and shocks or did she get her springs cut ...
if she got them cut she could go to Pt Augusta and find a pedders and get them to fit sum sports ridders with heavy duty shock and springs
Edited by Madaz
https://www.sau.com.au/forums/topic/100416-defected/#findComment-1838859
    • Done about 5k Km on the PS5's now, excellent street tyres, great in the dry, and the wet, seem to be wearing very well, I haven't measured tread depth, but it looks like minimal wear, I also had a different alignment done about 1500km ago,  From looking at the tread wear, which is really only minimal, the alignment changes were based off how the tread looked, and how it felt throwing it around, the changes have shown great results 215/45 17 at 32 psi Front Caster: 5.5° Camber: -1.5° Toe: 0.0mm Rear Camber: -1.0° Total Toe-in: 1.5mm I actually prefer PS5's now over the RS4's, as the PS5's are much better in the wet IMO, and as the MX5 gets driven in all weather conditions doing daily duties, hwy trips, and blasts in the mountains, wet weather grip is high on my priority list
    • To update this thread. I got sent a replacement Attesa pro unit and all is now working as expected. Cheers
    • FD is so sexy she can pull off tri-spokes
    • Indeed they do. Best my diff builder could tell is it's a combination of the different cut/angle and it would seem they lap them in well on accell but less so on decel. He had to use a slightly different pattern to the lap to get the best result noise wise. Also as the rear diff runs in, the whine is getting less.        Overall they seem like a good thing so far. He's done a few neat crown/pinion before but all for race cars with loud everything, in most cases the exhaust is louder, so I am the first to notice.... and be somewhat of a pain
    • What do you mean by "test"? It sounds like you're just switching things on and off that you already know don't work. Get the wiring diagram and a multimeter and start looking for power where there is supposed to be power and earth where there is supposed to be earth. Look for continuity across switches that are otherwise unresponsive, etc etc.
