I don't see why a crank collar properly fitted would not be good enough for 500hp.  It costs half as much or less 'but I might as well throw $500 in the river since I'm rebuilding the engine anyway'.  Note sarcasm - not rudely meant, just easier to use.
Also those pistons will not likely be lighter will they?  More likely the opposite.  Dunno about the rods.
:P No offence taken. I don't really want to throw $500 away on anything either. It just seems to me that to go to all this trouble while the motor is out and so on, and then pop the 12yr old crank back in - which has had to be modified (possibly weakened at this point?) - in the scheme of things $500 was good insurance... but hey, that's exactly why I am asking the question - to see what others have done/think on this.
Pistons I thought were lighter going to the forged items over the stock cast ones -aren't they?
The crower rods are about 200g lighter than the stock rods. (recently another was done, and my engine builder weighed them both).. so all this means less stress on the crank I would think.
once you fit the collar etc its still gonna need to be machined before goin back into the motor.
thats where the new crank works out near enough to the same costings, without the wait of workshops :P
The weak point on that crank is the oil pump drive which the collar deals with.
How is the crank getting weaker with age? A new crank is never perfect anyway, it still needs some machining.
Also please note I tied your 500hp power figure to my statement.
Forged pistons are generally heavier than cast but you are making up for it with those rods - whether you need them or not is another story.
But I am not going as full on as someone building an outright race car either.
if this is so....you dont really need the motec and cdi....i have a brand new power fc pro which may suit your application better....could do a swap perhaps. pm me for a chat if your keen to work something out with me.
Edited by DiRTgarage
If cranks are anything like engine blocks, my understanding is that there are distinct advantages refreshing a used item from a metalurgy point of view, that is, the used item has already hardened and done any warping/etc.
Anyone more knowledgable then me (ha! that's not hard :)) care to comment?
Fair enough. I suppose it was just my thought that perhaps the crank may have suffered some fatigue over that time. If not, and in keeping with what Lucien says about the metallurgy point of view - perhaps it is better to simply keep that one?
I'm all for saving the money if it really is no advantage.
:( Cheers for that, but I guess I meant I am not a "no limit to budget, out and out race car". I still intend to be 'racing' as much as I can.
Part of the reason I have Motec and CDI is because that what my tuner is most familiar with, and secondly - he sponsored me. :( He probably wouldn't like me to give it away like that. But thanks for the offer anyhow. Now if you want to swap a veilside front bar for that nice stock one you have - that's something I'd be interested in! :D
I just weighed the stock pistons in at 440grams - and the JE replacements are 335grams according to the specs.
25% less, or 100grams per pot saving - using this particular piston. Got to be good.
Take another 200grams off per rod and the crank surely is having a better time of things at 8000rpm - not to mention the faster spin up time?
I notice your using JE pistons what made you choose these?
I ask because I have a dilema of using JE's which I got at a good price or sourcing Weisco's which have teflon coating from the factory, which apparently are a closer fit and less noisy from cold start.
All advice appreciated.
Edited by Sinista32
Well that's interesting. Has anyone got a pic of the JE piston lying around?
Do they have short skirts?
I went for the wiseco's recently for the abovementioned reasons basically. Teflon coated skirts from factory, clearances are smaller than some, fairly quiet compared to some, nice long skirts for keeping square in the bore, not expensive.
This weight saving says to me you have even less reason to get a new crank.
Just my opinion.
Just my opinion.
Yeah I hear what you're saying. Perhaps the JE are thinner and/or have shorter skirts. (I've always preferred shorts skirts.. not just in pistons either...)
I'll have to see if I can get hold of one and post some pics. I don't think the JE have any coatings like the Wiseco's either... I was thinking of having them ceramic coated - but thats just the top, not the skirts.. How much are the Wiseco's?
Frankly, it was just what my engine builder suggested. He's always had a like for the JE stuff. I once used them in a V8 too. But to be honest - I'm sure the Wiseco are probably just as good. And I like the sound of the teflon... I'll ask him about it and see what he thinks, but I know he did say that most 'good forged pistons' these days are all very good.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
