  • Replies 285
Posted Images
Man those vids are schweeeet....... quick question thou... Any thoughts on how the KKR430 would perform on a RB25? You say the boost is great on the RB20.....just wondering if it would be a bit laggier on the RB25.....??
I would of thought it would be less laggier. Though i think the KKR480 would be better suited. I think Otomoto state they have gotten 260rwkw (could be wrong lon this figure) from the 480 on an RB25 neo
Thanks guys, yeah was a typo with the KKR480 / KKR430. IObviously the KKR430 would be less laggier on the RB25 as it is a smaller turbz on a larger engine....
As replicate answered (cheers champ) was wondering about the KKR480 on the RB25 in a bit more detail than what is listed on their site....
KKR-480
Suitable for larger 2.5–3.0L engines, this turbo features a twin-entry T3-size exhaust flange, which is also suitable for normal T3-flange manifolds such as RB25DET or RB30ET*. Rated at 480hp, it uses the same compressor design as the KKR-430, but a larger turbine and housing better suited to high-boost applications up to 20psi. It uses a 2.75in V-band flange for the exhaust outlet.
Tested by Croydon Racing Developments on an RB25DET Neo engine, it produced 242kW at the wheels at 18psi. The standard internal wastegate is designed to hold 14–15psi.
Just trying to establish if the is much modification required to fit the KKR480 to the RB25 as there is for the KKR430 to the RB20.......
Pay an extra few $$$ and get a straight bolt-up Garret.......
Oh well such are the dilehmas of the 'turbo game'
Ando
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
