Howdy All,
I know there was some interest here before in the MaxAuto Action events at Belmont Park Racecourse. This is just to let you know that the event series is kicking off with a double header on Saturday January 28th PM session (from 13:00) for the Porsche Car Club only and then 2 full sessions (AM 9:00 – 12:30 & PM 13:00 – 16:30) on Sunday, January 29th.
If you are interested in competing you would need to be quick to enter, as the event is already over 80% booked, with the following events also booked to about 70% level. However everyone is more than welcome to attend the events as spectators, which is still free of any charge. This season there will also be some food and soft drinks available, both supplied by members of the Lions Club for just a small charge.
For further info on the event: http://www.driveline.net.au/eventDetails.php?event_id=330
And here are some pictures from previous events:
http://www.bwmedia.com.au/cgi-bin/pro/emAl...0F1%20Autokhana
Entry Fee for the event if booked before January 7th is just $58 per event. If you are interested and you would like to receive an entry form or the 2006 Calendar of Events please sent me an email to [email protected] As you can see from the above, we have also started taking bookings for car club or group exclusive sessions, where a minimum number of 25 competitors is required. Please call me on 0418 922 733 if you’re interested.
Cheers,
Norbert
https://www.sau.com.au/forums/topic/100483-first-maxauto-action-series-round-1/
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
