hah, i bought a GTR bar cheap a few days ago with the idea of doing this as i have just installed a fmic.. it appears to line up fine, however id say it needs the GTR crash support as the GTST one does not line up at all, and no amount of hacking/cutting looks like it will make it.. i drive a 33 however, im not sure if its the same for a 32. on a side note im thinking of keeping the stocker front bar over the GTR bar cus in my oppinion you just cant beat that sleeper look :P
pics anyone thinking of doing this on a 4 door
Got a mate with Vertex kit on his four door, and GTR front bar... will get pics, can be done. Was thinking of doing on mine, but genuine GTR bar too much compared to my Vertex one.
does any one know of anywere to pic up cheap fibreglass copys
define cheap..
they can be had for about $400-450 brand new from:
www.carmate.com.au
www.jetspeed.com.au
www.justjap.com.au
i am also itnerested in putting a GTR bar on my car, but despite seeing that pic i'm still not convinvced. I have psoken to a person who bought a GTR bar for their R32 and it simply didn't fit at all.
Maybe its possible to get the stock plastic one modified (ie a bit of plastic removed to reduce the width) so that it fits properly?
cheers,
Warren.
^^ what he said...
also if you use a genuine GTR bar, if you use a genuine GTR bumper support (ie reo) you won't have to bend anything in the front, just the sides so they meet up witht he guards. The most common thing you see with R32 GTR bumpers on GTSt's is the 1cm or so gap under the headlights where the bumper bends.
You can avoid that by using a genuine GTR bumper support.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
