Having owned both cars myself.....
Very true that the 300 are hard to work on, however stock 3L manual do go very well. Few mods and you will have a fair bit of power for a NA. More so, the 300 engine for some reason seem to need more work...what I mean is that a lot of things get dirty, old, corroded and need maintenance. It seemed like I had to clean every little plug in the engine bay!! IMO the 300 look hot. My old 300 had exhaust, air filter and bit of engine work and it would keep up with a few v8 and give turbos a bit of a run!
However at the end of the day it is up to you, what you can afford, what you like better and also, what you can find because there is so much cr#p out there due to both of these cars being old!
If you upgrade to a TT 300 you will never look back. With basic mods the power is amazing! My second 300 was a TT and it use to eat skylines! However, maintenance on the TT is expensive and these days i prefer the 32, especially the interior!!!!
My 2 cents
Cheers
  • Replies 45
get an NA r33 series 2, i got one in may and payed 12,200 so prices carnt be that bad.
it had done 80,000k's and was in mint condition. =) (NOT ANYMORE!)
f**k the 300, to much to run. heavy + larger motor will mess with your funds
in my mind there is no comparison to an 89-91 model car and a 96....i dont think you would be able to pick up a 92+ model as they are alot more sort after. but who knows
300's are getting a bit old now and as mentioned in other posts, the engine is a nightmare to work on. Being an older car, there will be SOMETHING that will need replacing/maintenance in the engine bay and it's going to give you headaches.
Depending on your budget, I think the later the model of car you can buy the better. I don't like R33's much myself but if you could pick up an N/A series 2 R33 it would be your best bet. The later the model the better.
Second choice would be an R32 GTS25 (RB25DE) but once again they're getting a bit old so be prepared to fix a few things. Plus side is theyre usually easy as pie to work on, so it wont cost you as much.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
